Trek 4300 Bicycle Kickstand Replacement
    1. Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: step 1, image 1 of 2 Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: step 1, image 2 of 2
      • Flip the bike over so it is balanced and resting on the handlebar and the bike seat.
      • Using a socket screwdriver with a hex adapter, loosen the bolt that is holding the kickstand and bracket in place.
      • This may require a moderate amount of strength. Make sure you have the proper hex adapter as to not strip the bolt.
      Ask FixBot
    2. Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: step 2, image 1 of 2 Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: step 2, image 2 of 2
      • Once the bolt is loose, unscrew it the rest of the way by hand.
      • Remove the bolt. There should now be three separate pieces: the bolt, the bracket, and the kickstand.
      • Make sure to note the position of the bracket before you remove the bolt completely
      Ask FixBot
To replace the new kickstand, follow these instructions in reverse order.
Emily OConnor
500 Reputation
4 Guides authored
Clemson, Team 3-2, Benson Fall 2014 Member of Clemson, Team 3-2, Benson Fall 2014
CLEM-BENSON-F14S3G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 44
All Time: 3,460
