Trek 4300 Bicycle Front Wheel Replacement
  1. Trek 4300 Bicycle Front Wheel Replacement, Front Wheel: step 1, image 1 of 2 Trek 4300 Bicycle Front Wheel Replacement, Front Wheel: step 1, image 2 of 2
    • Stand facing your bike and locate the brake calipers.
    • To lessen the tension on the brake wire, place one hand on each caliper and push them closer together.
    Ask FixBot
  2. Trek 4300 Bicycle Front Wheel Replacement: step 2, image 1 of 2 Trek 4300 Bicycle Front Wheel Replacement: step 2, image 2 of 2
    • Unhook the brake wire in the metal tube from the brake wire holder on the brake caliper in your left hand.
    Ask FixBot
  3. Trek 4300 Bicycle Front Wheel Replacement: step 3, image 1 of 1
    • Find the quick release lever located on the bikes fork to loosen the wheel from the frame.
    • Lift the lever from lock position 180 degrees until the open sign on the lever faces outward. Twist the lever while holding the pin on the opposite side of the wheel.
    • The quick release lever does not need to be completely removed.
    • Note which side of the bike the quick release lever is on for proper reassembly.
    Ask FixBot
  4. Trek 4300 Bicycle Front Wheel Replacement: step 4, image 1 of 2 Trek 4300 Bicycle Front Wheel Replacement: step 4, image 2 of 2
    • Pull the frame of the bike upwards to separate the front wheel.
    Ask FixBot
Erin Ferguson
447 Reputation
4 Guides authored
Clemson, Team 3-2, Benson Fall 2014 Member of Clemson, Team 3-2, Benson Fall 2014
CLEM-BENSON-F14S3G2
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 2,921
