Treblab HD77 LED Light Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
56
All Time:
262
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
In this guide, you will learn how to replace the LED lights that are located on either side of the Treblab HD77. These LED lights indicate the current status of connectivity for the speaker and as a result are very helpful in using the speaker effectively. This guide aims to teach you how to replace these lights in the event that they stop working.
Note that this speaker is water resistant and as a result uses a water resistant adhesive in some areas which will have to be removed in certain areas in order to access the LEDs. To restore its water resistance, this adhesive will need to be manually reapplied before reassembling the speaker.
Make sure the device is powered off before disassembly.
    1. Treblab HD77 LED Light Replacement, Surround: step 1, image 1 of 3 Treblab HD77 LED Light Replacement, Surround: step 1, image 2 of 3 Treblab HD77 LED Light Replacement, Surround: step 1, image 3 of 3
      • Remove the outer casing of the speaker by prying at the edges to unlock each prong holding the casing to the speaker.
      Ask FixBot
    2. Treblab HD77 LED Light Replacement: step 2, image 1 of 3 Treblab HD77 LED Light Replacement: step 2, image 2 of 3 Treblab HD77 LED Light Replacement: step 2, image 3 of 3
      • Remove the plastic ring on top of the rubber surround on the side of the speaker by lifting it gently.
      • There is a layer of adhesive between the plastic ring and the rubber surround beneath it.
      Ask FixBot
    3. Treblab HD77 LED Light Replacement: step 3, image 1 of 3 Treblab HD77 LED Light Replacement: step 3, image 2 of 3 Treblab HD77 LED Light Replacement: step 3, image 3 of 3
      • Insert the blade of a small precision knife between the edge of the rubber surround and the plastic edge.
      • Gently apply pressure and slide the blade in a circle along the entire circumference until the surround loosens and can be removed.
      • There is a layer of adhesive between the surround and the plastic housing it is resting on.
      Ask FixBot
    1. Treblab HD77 LED Light Replacement, LED Light: step 4, image 1 of 3 Treblab HD77 LED Light Replacement, LED Light: step 4, image 2 of 3 Treblab HD77 LED Light Replacement, LED Light: step 4, image 3 of 3
      • Slide a small precision knife underneath the LED light strip and remove the adhesive holding it in place.
      • There are four points where adhesive is used to hold the LED light strip down.
      • Lift up the LED light strip from the plastic casing.
      Ask FixBot
    2. Treblab HD77 LED Light Replacement: step 5, image 1 of 3 Treblab HD77 LED Light Replacement: step 5, image 2 of 3 Treblab HD77 LED Light Replacement: step 5, image 3 of 3
      • Flip the LED light strip upside down to see where the cord is plugged in.
      • Gently pinch the wire with your pointer finger and thumb, and remove the cord from the LED slowly.
      • The cord is very thin and lightweight so use caution when handling.
      Ask FixBot
Matthew Szabo
775 Reputation
4 Guides authored
UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 Member of UMass Dartmouth, Team 3-5, Biswokarma Fall 2025
UMASSD-BISWOKARMA-F25S3G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 56
All Time: 262
