Traxxas Summit Steering Assembly Servo Replacement
  1. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: step 1, image 1 of 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: step 1, image 2 of 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: step 1, image 3 of 3
    • Remove each of the four pins that hold the shell by pulling them from the posts.
    Ask FixBot
  2. Traxxas Summit Steering Assembly Servo Replacement: step 2, image 1 of 2 Traxxas Summit Steering Assembly Servo Replacement: step 2, image 2 of 2
    • Remove the shell by grabbing it with both hands and lifting upwards.
    Ask FixBot
  3. Traxxas Summit Steering Assembly Servo Replacement: step 3, image 1 of 2 Traxxas Summit Steering Assembly Servo Replacement: step 3, image 2 of 2
    • Disconnect the battery from the device by pulling the black plastic connector apart.
    Ask FixBot
  4. Traxxas Summit Steering Assembly Servo Replacement: step 4, image 1 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 4, image 2 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 4, image 3 of 3
    • Disconnect the four power cables that connect the motor to the electronic speed control.
    • Grab the connectors by their rubber covered metal ends rather than the wire if possible.
    Ask FixBot
  5. Traxxas Summit Steering Assembly Servo Replacement: step 5, image 1 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 5, image 2 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 5, image 3 of 3
    • Unscrew the single 15.5mm long retaining bolt from the motor with the 3mm hex key.
    • Remove the motor by wiggling back and forth while pulling it to the right and up.
    Ask FixBot
  6. Traxxas Summit Steering Assembly Servo Replacement: step 6, image 1 of 2 Traxxas Summit Steering Assembly Servo Replacement: step 6, image 2 of 2
    • Flip the car on its back to provide access to the steering assembly.
    Ask FixBot
  7. Traxxas Summit Steering Assembly Servo Replacement: step 7, image 1 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 7, image 2 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 7, image 3 of 3
    • Unscrew the servo arm from the steering assembly by removing the 16.3mm long screw with a 2mm hex key.
    • Pull the connecting linkage out of the steering horn.
    Ask FixBot
  8. Traxxas Summit Steering Assembly Servo Replacement: step 8, image 1 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 8, image 2 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 8, image 3 of 3
    • Flip the car back upright.
    • Remove the two 7mm long screws retaining the largest wiring cover with the 2mm hex key.
    • Take the largest wiring cover off.
    • Remove the two 7mm long screws retaining the smaller wiring cover with the 2mm hex key.
    Ask FixBot
  9. Traxxas Summit Steering Assembly Servo Replacement: step 9, image 1 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 9, image 2 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 9, image 3 of 3
    • Remove the second wiring cover.
    • Pull the servo connecter out of the receiver.
    • Work the cable out of the receiver box.
    Ask FixBot
  10. Traxxas Summit Steering Assembly Servo Replacement: step 10, image 1 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 10, image 2 of 3 Traxxas Summit Steering Assembly Servo Replacement: step 10, image 3 of 3
    • Remove the four 9mm long screws that retain the faulty steering servo with the 2.5mm hex key.
    • Pull the servo out.
    • Turning the servo horn by hand may be necessary to fit it through the hole.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 80
All Time: 3,152
