Traxxas Slash Rear A-arm Replacement
    • Begin by setting the truck on a large flat service with it's shell off.
    • Hold the tire still and use the 6mm nut driver to remove the tire nut.
    • Remove the nut, tire, hex hub and drive pin and place them together so they won't get lost.
    Ask FixBot
    • Use the 5mm allen wrench to remove the screw from the hub carrier and A-arm connection.
    • This screw will not back out all the way by simply turning it counter-clockwise. You will want to turn the screw counter-clockwise until it stops moving, then pull the screw the rest of the way out.
    • Rotate the hub upwards and away from the A-arm until the drive-shaft disconnects into two parts.
    Ask FixBot
    • Use the 5mm allen wrench to remove the screw connecting the A-arm and the chassis.
    • Once this screw is removed, the A-arm will be free from the truck! Put the new A-arm in place of the old one and reverse these steps to re-assemble.
    Ask FixBot
Finish Line
Phillip Takahashi
87,893 Reputation
87 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 34
All Time: 1,747
