Up to 20% off select tools
Transforming High-Rise Pants into Low-Rise Style by Hand
Views: 1.7K
View statistics:
Past 24 Hours:
9
Past 7 Days:
54
Past 30 Days:
302
All Time:
1,692
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Transforming high-rise pants into low-rise ones can be a fun and creative way to update your wardrobe without the need to spend money. Whether you’re looking to follow current fashion trends or just want to give your old pants a new look, this guide will walk you through the process step-by-step. With a few simple tools and some basic sewing skills, you’ll be able to achieve a stylish and customized fit that suits your personal style!
    1. Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: step 1, image 1 of 2 Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: step 1, image 2 of 2
      • Begin by turning pants inside out and laying flat.
      Ask FixBot
    2. Transforming High-Rise Pants into Low-Rise Style by Hand: step 2, image 1 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 2, image 2 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 2, image 3 of 3
      • Line up the seams to match on both sides.
      • Mark where you would like the new bottom of your pants to sit.
      • Using a straight edge, mark a line going down from the initial mark down to the leg of the pants.
      Ask FixBot
    3. Transforming High-Rise Pants into Low-Rise Style by Hand: step 3, image 1 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 3, image 2 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 3, image 3 of 3
      • After the guide lines have been drawn out, cut off the fabric marked off leaving roughly 1cm for seam allowance.
      Ask FixBot
    4. Transforming High-Rise Pants into Low-Rise Style by Hand: step 4, image 1 of 2 Transforming High-Rise Pants into Low-Rise Style by Hand: step 4, image 2 of 2
      • Line up the fabric on both sides and pin together keeping the fabric in line.
      Ask FixBot
    5. Transforming High-Rise Pants into Low-Rise Style by Hand: step 5, image 1 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 5, image 2 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 5, image 3 of 3
      • Thread your needle with a thread close to the color of the pants you are altering.
      • Tie the ends of the thread into a knot large enough to not go through the fabric being sewn.
      Ask FixBot
    6. Transforming High-Rise Pants into Low-Rise Style by Hand: step 6, image 1 of 2 Transforming High-Rise Pants into Low-Rise Style by Hand: step 6, image 2 of 2
      • Insert the needle into the bottom of the marked line to begin your stitch.
      Ask FixBot
    7. Transforming High-Rise Pants into Low-Rise Style by Hand: step 7, image 1 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 7, image 2 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 7, image 3 of 3
      • Pull thread through the fabric and reinsert leaving about 1mm in between.
      • Insert the needle on the back side of the fabric about 1mm away from the previous stitch.
      • Insert the needle back into the initial stitch to create a backstitch.
      Ask FixBot
    8. Transforming High-Rise Pants into Low-Rise Style by Hand: step 8, image 1 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 8, image 2 of 3 Transforming High-Rise Pants into Low-Rise Style by Hand: step 8, image 3 of 3
      • Continue backstitching all around the marked line.
      • Tie off the thread once you reach the end by tying a knot into the final stitch.
      Ask FixBot
    9. Transforming High-Rise Pants into Low-Rise Style by Hand: step 9, image 1 of 2 Transforming High-Rise Pants into Low-Rise Style by Hand: step 9, image 2 of 2
      • Flip pants right side out and enjoy your new low-rise pants!
      Ask FixBot
Finish Line
Author
with
Addison Cavenee
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 54
Past 30 Days: 302
All Time: 1,692
