Toyota Yaris Key Battery Replacement
    1. Toyota Yaris Key Battery Replacement, Remove Key: step 1, image 1 of 3 Toyota Yaris Key Battery Replacement, Remove Key: step 1, image 2 of 3 Toyota Yaris Key Battery Replacement, Remove Key: step 1, image 3 of 3
      • Release latch on back of key and pull from key ring to remove the backup metal key from the rest of the fob.
      Ask FixBot
    2. Toyota Yaris Key Battery Replacement, Split key fob: step 2, image 1 of 2 Toyota Yaris Key Battery Replacement, Split key fob: step 2, image 2 of 2
      • Using a knife or small flat blade screwdriver pry open the two halves of the key.
      • To avoid cosmetic damage start from the inside where the metal key was removed in the previous step.
      Ask FixBot
    3. Toyota Yaris Key Battery Replacement, Remove battery cover: step 3, image 1 of 2 Toyota Yaris Key Battery Replacement, Remove battery cover: step 3, image 2 of 2
      • Remove black circular cover, underneath is an O-ring and the battery.
      Ask FixBot
    4. Toyota Yaris Key Battery Replacement, Replace Battery: step 4, image 1 of 1
      • Battery can easily be removed and replaced. Using CR2025 3V battery, ensure writing is visible with battery installed.
      • To reassemble reverse steps, install battery cover, snap the two halves together and push metal key back into its receptacle (no tools required for reassembly).
      Ask FixBot
Wieli
2,171 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 78
Past 30 Days: 256
All Time: 4,834
