Toyota Sienna 2009 Lightbulb Replacement Replacement
  1. Toyota Sienna 2009 Lightbulb Replacement Replacement, Lightbulb Replacement: step 1, image 1 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement, Lightbulb Replacement: step 1, image 2 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement, Lightbulb Replacement: step 1, image 3 of 3
    • Locate the latch on the bottom left of steering wheel.
    • Once found, pull in your direction.
    Ask FixBot
  2. Toyota Sienna 2009 Lightbulb Replacement Replacement: step 2, image 1 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement: step 2, image 2 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement: step 2, image 3 of 3
    • Now that you have unlocked the hood, locate the latch on top of the logo to fully release the hood.
    • Once found, lift the latch upwards and you have now freed the hood.
    Ask FixBot
  3. Toyota Sienna 2009 Lightbulb Replacement Replacement: step 3, image 1 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement: step 3, image 2 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement: step 3, image 3 of 3
    • Locate the lightbulb by locating the access compartment.
    • Once located, twist the compartment counter-clockwise and pull to free the lighbulb.
    • The plastic holding the compartment in place should appear in the gap shown in the picture.
    Ask FixBot
  4. Toyota Sienna 2009 Lightbulb Replacement Replacement: step 4, image 1 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement: step 4, image 2 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement: step 4, image 3 of 3
    • Turn the back of the bulb connector towards yourself, and prepare to remove the clasp, freeing the bulb.
    • In order to free the bulb, press firmly on the clasp, and pull with enough force to pull it out, but not enough to break it.
    Ask FixBot
  5. Toyota Sienna 2009 Lightbulb Replacement Replacement: step 5, image 1 of 2 Toyota Sienna 2009 Lightbulb Replacement Replacement: step 5, image 2 of 2
    • Once you have the new lightbulb ready, it is time to put everything back together.
    • Simply press the new bulb into where the old one was, making sure it is locked into the clasp.
    Ask FixBot
  6. Toyota Sienna 2009 Lightbulb Replacement Replacement: step 6, image 1 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement: step 6, image 2 of 3 Toyota Sienna 2009 Lightbulb Replacement Replacement: step 6, image 3 of 3
    • Line the connector with the empty point of where it is supposed to be locked in.
    • And this time, twist it clockwise to lock it into place.
    Ask FixBot
  7. Toyota Sienna 2009 Lightbulb Replacement Replacement: step 7, image 1 of 1
    • That's it! You are all done! Congratulations on accomplishing this easy and simple fix.
    Ask FixBot
Muhammad Aqeel
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 31
All Time: 605
