Toy Lightsaber Battery Replacement
    1. Toy Lightsaber Battery Replacement, Battery: step 1, image 1 of 3 Toy Lightsaber Battery Replacement, Battery: step 1, image 2 of 3 Toy Lightsaber Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the Lightsaber blade by carefully twisting it off the hilt.
      • Be gentle during this process to avoid damaging the blade or the hilt.
      Ask FixBot
    2. Toy Lightsaber Battery Replacement: step 2, image 1 of 3 Toy Lightsaber Battery Replacement: step 2, image 2 of 3 Toy Lightsaber Battery Replacement: step 2, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the 3.5 mm screws on the hilt.
      Ask FixBot
    3. Toy Lightsaber Battery Replacement: step 3, image 1 of 3 Toy Lightsaber Battery Replacement: step 3, image 2 of 3 Toy Lightsaber Battery Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the old C batteries.
      • If the batteries were leaking, be sure you thoroughly clean the inside of the hilt with a pair of tweezers to scrape off the battery acid and wipe away any acid that remains with a tissue or napkin.
      • Battery acid is toxic and dangerous for your health. Wear gloves to protect yourself.
      Ask FixBot
    4. Toy Lightsaber Battery Replacement: step 4, image 1 of 3 Toy Lightsaber Battery Replacement: step 4, image 2 of 3 Toy Lightsaber Battery Replacement: step 4, image 3 of 3
      • Place the new C batteries inside the newly cleaned hilt.
      Ask FixBot
    5. Toy Lightsaber Battery Replacement: step 5, image 1 of 3 Toy Lightsaber Battery Replacement: step 5, image 2 of 3 Toy Lightsaber Battery Replacement: step 5, image 3 of 3
      • Use your Philips #2 screwdriver to screw the 3.5 mm screws back into the hilt.
      Ask FixBot
    6. Toy Lightsaber Battery Replacement: step 6, image 1 of 3 Toy Lightsaber Battery Replacement: step 6, image 2 of 3 Toy Lightsaber Battery Replacement: step 6, image 3 of 3
      • Lastly, twist the Lightsaber blade back on top of the hilt.
      • Press the red button on the hilt to test if the blade glows.
      • If the blade doesn't glow, start over and try again with different C batteries.
      Ask FixBot
Zachary Adaes
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 87
All Time: 5,646
