TotalPond Pond Pump Impeller Spindle Replacement
  1. TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: step 1, image 1 of 3 TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: step 1, image 2 of 3 TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: step 1, image 3 of 3
    • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
    Ask FixBot
  2. TotalPond Pond Pump Impeller Spindle Replacement: step 2, image 1 of 3 TotalPond Pond Pump Impeller Spindle Replacement: step 2, image 2 of 3 TotalPond Pond Pump Impeller Spindle Replacement: step 2, image 3 of 3
    • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
    Ask FixBot
  3. TotalPond Pond Pump Impeller Spindle Replacement: step 3, image 1 of 2 TotalPond Pond Pump Impeller Spindle Replacement: step 3, image 2 of 2
    • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller. Also remove the bearing that is between the stop and the impeller.
    Ask FixBot
  4. TotalPond Pond Pump Impeller Spindle Replacement: step 4, image 1 of 2 TotalPond Pond Pump Impeller Spindle Replacement: step 4, image 2 of 2
    • Hold the impeller cover with one hand and the impeller with the other. Slide the impeller out.
    Ask FixBot
  5. TotalPond Pond Pump Impeller Spindle Replacement: step 5, image 1 of 2 TotalPond Pond Pump Impeller Spindle Replacement: step 5, image 2 of 2
    • Hold the impeller spindle and wiggle it side to side until it detaches from the impeller cover.
    Ask FixBot
Nicole Santana
612 Reputation
5 Guides authored
USF Tampa, Team 3-6, Hickman Winter 2015 Member of USF Tampa, Team 3-6, Hickman Winter 2015
USFT-HICKMAN-W15S3G6
4 Members
5 Guides authored
1 Guide Comment
The part number of the spindle itself would probably be a good idea to included in this guide.
rz22g - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 38
All Time: 1,694
