Up to 20% off select tools
Toshiba Thrive Front Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
81
All Time:
921
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show you how to replace your front camera.
    1. Toshiba Thrive Front Camera Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the lock switch for the back cover is unlocked.
      • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
      Ask FixBot
    2. Toshiba Thrive Front Camera Replacement: step 2, image 1 of 2 Toshiba Thrive Front Camera Replacement: step 2, image 2 of 2
      • Remove back cover by prying away from the Thrive.
      • The easiest place to pry from is one of the two speakers.
      Ask FixBot
    3. Toshiba Thrive Front Camera Replacement: step 3, image 1 of 1
      • To remove the battery, make sure the lock switch is in the unlocked position.
      • The battery is unlocked when the switch is slid to the unlocked position.
      Ask FixBot
    4. Toshiba Thrive Front Camera Replacement: step 4, image 1 of 3 Toshiba Thrive Front Camera Replacement: step 4, image 2 of 3 Toshiba Thrive Front Camera Replacement: step 4, image 3 of 3
      • Slide the battery switch release to the right.
      • While holding the switch in place, lift up the battery.
      Ask FixBot
    1. Toshiba Thrive Front Camera Replacement, Midframe: step 5, image 1 of 2 Toshiba Thrive Front Camera Replacement, Midframe: step 5, image 2 of 2
      • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
      • All of these screws are identical so don't worry about getting them mixed up.
      Ask FixBot
    2. Toshiba Thrive Front Camera Replacement: step 6, image 1 of 3 Toshiba Thrive Front Camera Replacement: step 6, image 2 of 3 Toshiba Thrive Front Camera Replacement: step 6, image 3 of 3
      • Start to gently pry the back of the device off, while leaving it loosely in place.
      • Be careful not to tear or damage the cables when removing the back.
      Ask FixBot
    3. Toshiba Thrive Front Camera Replacement: step 7, image 1 of 3 Toshiba Thrive Front Camera Replacement: step 7, image 2 of 3 Toshiba Thrive Front Camera Replacement: step 7, image 3 of 3
      • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
      Ask FixBot
    4. Toshiba Thrive Front Camera Replacement: step 8, image 1 of 2 Toshiba Thrive Front Camera Replacement: step 8, image 2 of 2
      • Carefully open the device like a book and lay the two halves beside each other.
      Ask FixBot
    1. Toshiba Thrive Front Camera Replacement, Front Camera: step 9, image 1 of 2 Toshiba Thrive Front Camera Replacement, Front Camera: step 9, image 2 of 2
      • Separate the two halves of your Thrive
      • Using a Phillips screwdriver, remove the six screws holding the LCD in place. These screws are 3mm in length and require a PH0 screwdriver.
      Ask FixBot
    2. Toshiba Thrive Front Camera Replacement: step 10, image 1 of 1
      • With a spudger, disconnect the cable connecting the camera to the motherboard.
      Ask FixBot
    3. Toshiba Thrive Front Camera Replacement: step 11, image 1 of 2 Toshiba Thrive Front Camera Replacement: step 11, image 2 of 2
      • Lift up the LCD from the screen and place it on the side
      Ask FixBot
    4. Toshiba Thrive Front Camera Replacement: step 12, image 1 of 2 Toshiba Thrive Front Camera Replacement: step 12, image 2 of 2
      • Remove the one screw holding the camera in place. The screw is 3mm in length and requires a PH0 screwdriver.
      • Lift up the camera from the screen.
      Ask FixBot
Author
with
Kason
1,120 Reputation
5 Guides authored
USF Tampa, Team 10-1, Brown Fall 2014 Member of USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 81
All Time: 921
