Toshiba Thrive Charging Port Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
89
All Time:
4,522
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will show you the steps required to remove your charging port.
Tools
    1. Toshiba Thrive Charging Port Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the lock switch for the back cover is unlocked.
      • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
      Ask FixBot
    2. Toshiba Thrive Charging Port Replacement: step 2, image 1 of 2 Toshiba Thrive Charging Port Replacement: step 2, image 2 of 2
      • Remove back cover by prying away from the Thrive.
      • The easiest place to pry from is one of the two speakers.
      Ask FixBot
    3. Toshiba Thrive Charging Port Replacement: step 3, image 1 of 1
      • To remove the battery, make sure the lock switch is in the unlocked position.
      • The battery is unlocked when the switch is slid to the unlocked position.
      Ask FixBot
    4. Toshiba Thrive Charging Port Replacement: step 4, image 1 of 3 Toshiba Thrive Charging Port Replacement: step 4, image 2 of 3 Toshiba Thrive Charging Port Replacement: step 4, image 3 of 3
      • Slide the battery switch release to the right.
      • While holding the switch in place, lift up the battery.
      Ask FixBot
    1. Toshiba Thrive Charging Port Replacement, Midframe: step 5, image 1 of 2 Toshiba Thrive Charging Port Replacement, Midframe: step 5, image 2 of 2
      • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
      • All of these screws are identical so don't worry about getting them mixed up.
      Ask FixBot
    2. Toshiba Thrive Charging Port Replacement: step 6, image 1 of 3 Toshiba Thrive Charging Port Replacement: step 6, image 2 of 3 Toshiba Thrive Charging Port Replacement: step 6, image 3 of 3
      • Start to gently pry the back of the device off, while leaving it loosely in place.
      • Be careful not to tear or damage the cables when removing the back.
      Ask FixBot
    3. Toshiba Thrive Charging Port Replacement: step 7, image 1 of 3 Toshiba Thrive Charging Port Replacement: step 7, image 2 of 3 Toshiba Thrive Charging Port Replacement: step 7, image 3 of 3
      • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
      Ask FixBot
    4. Toshiba Thrive Charging Port Replacement: step 8, image 1 of 2 Toshiba Thrive Charging Port Replacement: step 8, image 2 of 2
      • Carefully open the device like a book and lay the two halves beside each other.
      Ask FixBot
    1. Toshiba Thrive Charging Port Replacement, Charging Port: step 9, image 1 of 3 Toshiba Thrive Charging Port Replacement, Charging Port: step 9, image 2 of 3 Toshiba Thrive Charging Port Replacement, Charging Port: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the two screws holding the charging port in place. The screws are 3mm in length and require a PH0 screwdriver.
      • Using a pair of tweezers, lift up the charging port's protective covering
      Ask FixBot
    2. Toshiba Thrive Charging Port Replacement: step 10, image 1 of 3 Toshiba Thrive Charging Port Replacement: step 10, image 2 of 3 Toshiba Thrive Charging Port Replacement: step 10, image 3 of 3
      • Use the tweezers to pull out the connector connecting the charging port to the motherboard.
      • Using the tweezers again, gently lift up the charging port from your Thrive.
      Ask FixBot
7 other people completed this guide.
Kason
1,120 Reputation
5 Guides authored
USF Tampa, Team 10-1, Brown Fall 2014 Member of USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 Members
72 Guides authored
1 Guide Comment
I added "better pictures" flag because i was having trouble following the last step cause i couldnt see anything.
Sun Fai Lau - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 89
All Time: 4,522
