Toshiba Thrive Battery Replacement
    1. Toshiba Thrive Battery Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the lock switch for the back cover is unlocked.
      • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
      Ask FixBot
    2. Toshiba Thrive Battery Replacement: step 2, image 1 of 2 Toshiba Thrive Battery Replacement: step 2, image 2 of 2
      • Remove back cover by prying away from the Thrive.
      • The easiest place to pry from is one of the two speakers.
      Ask FixBot
    3. Toshiba Thrive Battery Replacement: step 3, image 1 of 1
      • To remove the battery, make sure the lock switch is in the unlocked position.
      • The battery is unlocked when the switch is slid to the unlocked position.
      Ask FixBot
    4. Toshiba Thrive Battery Replacement: step 4, image 1 of 3 Toshiba Thrive Battery Replacement: step 4, image 2 of 3 Toshiba Thrive Battery Replacement: step 4, image 3 of 3
      • Slide the battery switch release to the right.
      • While holding the switch in place, lift up the battery.
      Ask FixBot
7 other people completed this guide.
Kason
1,120 Reputation
5 Guides authored
USF Tampa, Team 10-1, Brown Fall 2014 Member of USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 Members
72 Guides authored
1 Guide Comment
You should give links on where we can buy the parts that need to be replaced.
Meggie Guerrer - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 103
All Time: 2,839
