Toshiba Tecra Z50-A RAM Replacement
    1. Toshiba Tecra Z50-A RAM Replacement, Back Panel: step 1, image 1 of 1
      • Turn off the laptop.
      • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
      • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
      Ask FixBot
    2. Toshiba Tecra Z50-A RAM Replacement: step 2, image 1 of 1
      • Lift up back panel using your hands and remove it from the rest of the laptop.
      Ask FixBot
    1. Toshiba Tecra Z50-A RAM Replacement, Battery: step 3, image 1 of 1
      • Lift the plastic covering over the battery plug.
      Ask FixBot
    2. Toshiba Tecra Z50-A RAM Replacement: step 4, image 1 of 1
      • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
      Ask FixBot
    3. Toshiba Tecra Z50-A RAM Replacement: step 5, image 1 of 1
      • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
      Ask FixBot
    4. Toshiba Tecra Z50-A RAM Replacement: step 6, image 1 of 1
      • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
      Ask FixBot
    5. Toshiba Tecra Z50-A RAM Replacement: step 7, image 1 of 1
      • Lift up on the battery with your hands and remove it from the laptop.
      Ask FixBot
    1. Toshiba Tecra Z50-A RAM Replacement, RAM: step 8, image 1 of 1
      • Pull the two retention clips outwards.
      Ask FixBot
    2. Toshiba Tecra Z50-A RAM Replacement: step 9, image 1 of 3 Toshiba Tecra Z50-A RAM Replacement: step 9, image 2 of 3 Toshiba Tecra Z50-A RAM Replacement: step 9, image 3 of 3
      • Pull up on the RAM module at a 45 degree angle.
      Ask FixBot
Luis Juen Baez
585 Reputation
4 Guides authored
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 74
All Time: 981
