Toshiba Tecra M2 CPU Replacement
    1. Toshiba Tecra M2 CPU Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop upside down so the back compartment is facing up.
      • Place left thumb on the battery lock tab.
      • Place right thumb on the battery release latch.
      Ask FixBot
    2. Toshiba Tecra M2 CPU Replacement: step 2, image 1 of 2 Toshiba Tecra M2 CPU Replacement: step 2, image 2 of 2
      • Slide both tabs outward at the same time to release battery pack.
      Ask FixBot
    3. Toshiba Tecra M2 CPU Replacement: step 3, image 1 of 1
      • Pull out the battery after it has popped out and set aside.
      • The battery and the battery cover are in one piece
      Ask FixBot
    1. Toshiba Tecra M2 CPU Replacement, CPU: step 4, image 1 of 1
      • Use a #00 phillips head screwdriver to remove the 8mm screw for the keyboard strip located under the battery.
      Ask FixBot
    2. Toshiba Tecra M2 CPU Replacement: step 5, image 1 of 1
      • Turn the device over and open it up to the display.
      • Gently lift a corner of the keyboard strip until it pops out of its position.
      Ask FixBot
    3. Toshiba Tecra M2 CPU Replacement: step 6, image 1 of 1
      • Using a #00 phillips head screwdriver, remove the two 4mm screws found underneath the keyboard strip.
      Ask FixBot
    4. Toshiba Tecra M2 CPU Replacement: step 7, image 1 of 2 Toshiba Tecra M2 CPU Replacement: step 7, image 2 of 2
      • Pop the keyboard up gently and rest on top of the touch pad
      • The keyboard is attached underneath by a thin film. Do not rip the keyboard off. Gently lay it down without ripping the film.
      Ask FixBot
    5. Toshiba Tecra M2 CPU Replacement: step 8, image 1 of 2 Toshiba Tecra M2 CPU Replacement: step 8, image 2 of 2
      • Using a #00 phillips head screwdriver, remove the 6mm screw holding the metal plate down.
      Ask FixBot
    6. Toshiba Tecra M2 CPU Replacement: step 9, image 1 of 2 Toshiba Tecra M2 CPU Replacement: step 9, image 2 of 2
      • Gently remove the keyboard connector film from the motherboard with fingers by lifting upwards.
      • Set aside the keyboard.
      Ask FixBot
    7. Toshiba Tecra M2 CPU Replacement: step 10, image 1 of 1
      • Using a #00 phillips head screwdriver, remove the three 13mm screws holding down the touch pad's frame from underneath the keyboard.
      Ask FixBot
    8. Toshiba Tecra M2 CPU Replacement: step 11, image 1 of 3 Toshiba Tecra M2 CPU Replacement: step 11, image 2 of 3 Toshiba Tecra M2 CPU Replacement: step 11, image 3 of 3
      • Flip laptop back upside down.
      • Remove the 5mm lock screw, using a #00 phillips head screwdriver.
      • Slide bay latch toward the battery compartment.
      • Remove CD-RW/DVD-ROM drive.
      Ask FixBot
    9. Toshiba Tecra M2 CPU Replacement: step 12, image 1 of 1
      • Remove the 4.5mm screw located under the CD-RW/DVD-ROM drive compartment, using a #00 phillips head screwdriver.
      Ask FixBot
    10. Toshiba Tecra M2 CPU Replacement: step 13, image 1 of 1
      • Remove the three 17mm screws found on the backside of the laptop using a #00 phillips head screwdriver.
      • Remove the ten 8mm screws using a #00 phillips head screwdriver.
      Ask FixBot
    11. Toshiba Tecra M2 CPU Replacement: step 14, image 1 of 2 Toshiba Tecra M2 CPU Replacement: step 14, image 2 of 2
      Tool used on this step:
      Buy
      • Flip the laptop back over and unplug the touch pad's power cord from the motherboard gently using a pair of tweezers.
      Ask FixBot
    12. Toshiba Tecra M2 CPU Replacement: step 15, image 1 of 2 Toshiba Tecra M2 CPU Replacement: step 15, image 2 of 2
      • Lift off the plastic cover and set it aside.
      Ask FixBot
    13. Toshiba Tecra M2 CPU Replacement: step 16, image 1 of 2 Toshiba Tecra M2 CPU Replacement: step 16, image 2 of 2
      • Using a #00 phillips head screwdriver, unscrew the three 5mm screws holding down the heat sink securing bracket.
      • Lift off the securing bracket and set aside.
      Ask FixBot
    14. Toshiba Tecra M2 CPU Replacement: step 17, image 1 of 1
      • Wiggle the heat sink until it lifts off the top of your CPU. There is thermal paste underneath and it may stick.
      Ask FixBot
    15. Toshiba Tecra M2 CPU Replacement: step 18, image 1 of 3 Toshiba Tecra M2 CPU Replacement: step 18, image 2 of 3 Toshiba Tecra M2 CPU Replacement: step 18, image 3 of 3
      • Turn a flathead #3 screwdriver counter-clockwise to unlock the CPU socket.
      • Grab the CPU with your index finger and thumb and pull directly upwards.
      • Apply a new coat of thermal paste before reassembling.
      • How to Apply Thermal Paste
      Ask FixBot
2 other people completed this guide.
Cindy Nguyen
398 Reputation
3 Guides authored
CSU Fullerton, Team 1-6, Bruce Fall 2014 Member of CSU Fullerton, Team 1-6, Bruce Fall 2014
CSUF-BRUCE-F14S1G6
3 Members
36 Guides authored
1 Guide Comment
"Step 4 - CPU" THAT IS NOT A 8MM SCREW! THERE IS NOW A HOLE IN MY COMPUTER!!
[deleted] - Reply Share
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 113
All Time: 2,260
