Toshiba Tecra 8200 RAM Replacement
    1. Toshiba Tecra 8200 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn off the device and unplug the power cord.
      • To remove the battery, flip the device, so that the bottom is facing upward.
      Ask FixBot
    2. Toshiba Tecra 8200 RAM Replacement: step 2, image 1 of 3 Toshiba Tecra 8200 RAM Replacement: step 2, image 2 of 3 Toshiba Tecra 8200 RAM Replacement: step 2, image 3 of 3
      • Slide the battery to the right side until you hear a click.
      • Carefully remove the battery from its compartment.
      Ask FixBot
    1. Toshiba Tecra 8200 RAM Replacement, RAM: step 3, image 1 of 1
      • Position device so the screen is face down.
      • Locate RAM Panel.
      Ask FixBot
    2. Toshiba Tecra 8200 RAM Replacement: step 4, image 1 of 2 Toshiba Tecra 8200 RAM Replacement: step 4, image 2 of 2
      • Remove two Phillips #00 screws labeled F4.
      • Remove panel.
      Ask FixBot
    3. Toshiba Tecra 8200 RAM Replacement: step 5, image 1 of 2 Toshiba Tecra 8200 RAM Replacement: step 5, image 2 of 2
      • Pinch clips on each side of RAM chips to release.
      • Gently remove RAM chips at a 45 degree angle. Use a plastic opening tool if RAM chips do not pop open.
      Ask FixBot
Sally
306 Reputation
3 Guides authored
Ohio State, Team 1-3, Buehl Winter 2015 Member of Ohio State, Team 1-3, Buehl Winter 2015
OSU-BUEHL-W15S1G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 113
All Time: 834
