Toshiba TY-LP 200 Belt Replacement
  1. Toshiba TY-LP 200 Belt Replacement, Belt: step 1, image 1 of 2 Toshiba TY-LP 200 Belt Replacement, Belt: step 1, image 2 of 2
    • Unplug the turntable and remove the dust cover by lifting the lid horizontally.
    Ask FixBot
  2. Toshiba TY-LP 200 Belt Replacement: step 2, image 1 of 2 Toshiba TY-LP 200 Belt Replacement: step 2, image 2 of 2
    • Locate the C-clip at the center base of the platter and remove it with a flathead screwdriver.
    Ask FixBot
  3. Toshiba TY-LP 200 Belt Replacement: step 3, image 1 of 2 Toshiba TY-LP 200 Belt Replacement: step 3, image 2 of 2
    • Once removed, very gently lift the platter straight up and off the device.
    • Flip the platter upside down.
    Ask FixBot
  4. Toshiba TY-LP 200 Belt Replacement: step 4, image 1 of 3 Toshiba TY-LP 200 Belt Replacement: step 4, image 2 of 3 Toshiba TY-LP 200 Belt Replacement: step 4, image 3 of 3
    • Place the new belt around the center ring of the upside-down platter.
    • After placing the new belt, stretch the belt towards one of the indented areas on the back of the platter.
    Ask FixBot
  5. Toshiba TY-LP 200 Belt Replacement: step 5, image 1 of 1
    • Locate the spool drive that is surrounded by three screws.
    Ask FixBot
  6. Toshiba TY-LP 200 Belt Replacement: step 6, image 1 of 1
    • Once you have located the spool drive, place the stretched belt over it, and gently put back the platter into its original form, as shown in step 2.
    • If this step is done correctly, once the platter is spun, it will stop by itself.
    Ask FixBot
  7. Toshiba TY-LP 200 Belt Replacement: step 7, image 1 of 2 Toshiba TY-LP 200 Belt Replacement: step 7, image 2 of 2
    • Place the C-type back into its original place and, with your finger, attach it onto the spindle.
    • Reinstall the dust cover by placing it on the snaps and applying force downwards.
    Ask FixBot
You now have a fixed and working record player.
Andrew
145 Reputation
1 Guide authored
3 Guide Comments
Thank you so much for this! Incredibly helpful!!!
Judi Dell'Anno - Reply Share
Replacement belt size?
lyam_pa - Reply Share
Along with this fix, I tried to clean a bit of dust and grime that's accumulated throughout the 3 decades. Some is not coming off with vacuuming or dry-wiping. Any advice on how to clean the unit up before reassembly? Mine is a gold Marantz with similar design and some of its parts are not as smooth as they should be. Thanks so much
Edie K - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 56
All Time: 2,081
