Toshiba TDP-XP2 Fuse Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
63
All Time:
878
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
In the rare case of a power surge, if the device is not plugged into a surge protecting outlet, the fuse will blow out and need to be replaced. This guide will show how to tear the whole projector down to get the fuse and replace it.
Parts
Tools
    1. Toshiba TDP-XP2 Fuse Replacement, Fuse: step 1, image 1 of 3 Toshiba TDP-XP2 Fuse Replacement, Fuse: step 1, image 2 of 3 Toshiba TDP-XP2 Fuse Replacement, Fuse: step 1, image 3 of 3
      • Start by removing the two screws on the bottom of the device as shown.
      Ask FixBot
    2. Toshiba TDP-XP2 Fuse Replacement: step 2, image 1 of 2 Toshiba TDP-XP2 Fuse Replacement: step 2, image 2 of 2
      • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
      • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
      Ask FixBot
    3. Toshiba TDP-XP2 Fuse Replacement: step 3, image 1 of 3 Toshiba TDP-XP2 Fuse Replacement: step 3, image 2 of 3 Toshiba TDP-XP2 Fuse Replacement: step 3, image 3 of 3
      • Remove the screws from the case located around the device.
      Ask FixBot
    4. Toshiba TDP-XP2 Fuse Replacement: step 4, image 1 of 1
      • Remove the plastic panels from the body.
      Ask FixBot
    5. Toshiba TDP-XP2 Fuse Replacement: step 5, image 1 of 3 Toshiba TDP-XP2 Fuse Replacement: step 5, image 2 of 3 Toshiba TDP-XP2 Fuse Replacement: step 5, image 3 of 3
      • Remove the screws from the IO panel.
      • Pull up on the panel and remove it.
      Ask FixBot
    6. Toshiba TDP-XP2 Fuse Replacement: step 6, image 1 of 2 Toshiba TDP-XP2 Fuse Replacement: step 6, image 2 of 2
      • Unscrew the screws from the metal shielding to remove it.
      Ask FixBot
    7. Toshiba TDP-XP2 Fuse Replacement: step 7, image 1 of 3 Toshiba TDP-XP2 Fuse Replacement: step 7, image 2 of 3 Toshiba TDP-XP2 Fuse Replacement: step 7, image 3 of 3
      • Remove cables from motherboard.
      • Unscrew motherboard and remove from device.
      Ask FixBot
    8. Toshiba TDP-XP2 Fuse Replacement: step 8, image 1 of 1
      • Remove the cable from the bottom of the motherboard to fully remove it.
      Ask FixBot
    9. Toshiba TDP-XP2 Fuse Replacement: step 9, image 1 of 1
      • Unscrew the power adapter on the back.
      Ask FixBot
    10. Toshiba TDP-XP2 Fuse Replacement: step 10, image 1 of 2 Toshiba TDP-XP2 Fuse Replacement: step 10, image 2 of 2
      • Remove cables from the power supply board.
      • Remove the screws located around the board to un-mount it.
      Ask FixBot
    11. Toshiba TDP-XP2 Fuse Replacement: step 11, image 1 of 2 Toshiba TDP-XP2 Fuse Replacement: step 11, image 2 of 2
      • Locate the fuse near where the power adapter was.
      • De-solder the fuse and replace with an equivalent fuse (Fuse leads to de-solder are marked in red).
      Ask FixBot
Bryan Underwood
697 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 63
All Time: 878
