Toshiba SD-K740 Disc Drive Replacement
    1. Toshiba SD-K740 Disc Drive Replacement, Top Panel: step 1, image 1 of 1
      • Unplug the DVD player before beginning.
      • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
      Ask FixBot
    2. Toshiba SD-K740 Disc Drive Replacement: step 2, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement: step 2, image 2 of 2
      • Turn the DVD player on its side.
      • Remove the 7.7 mm screw.
      • Flip the DVD player onto its other side.
      Ask FixBot
    3. Toshiba SD-K740 Disc Drive Replacement: step 3, image 1 of 1
      • Flip the DVD player over onto its front face.
      • Remove the back panel by lifting up and pulling it towards yourself.
      Ask FixBot
    1. Toshiba SD-K740 Disc Drive Replacement, Front Panel: step 4, image 1 of 1
      • Flip the DVD player so its top is sitting on your working surface.
      • Lift and push away the two tabs located in the middle of the player.
      • The front panel will not detach during this step, so do not force it.
      Ask FixBot
    2. Toshiba SD-K740 Disc Drive Replacement: step 5, image 1 of 1
      • Flip the DVD player on its side.
      • Lift and slide forward the single tab on the side.
      Ask FixBot
    3. Toshiba SD-K740 Disc Drive Replacement: step 6, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement: step 6, image 2 of 2
      • Grasp the front panel and pull forward to your right to remove it.
      Ask FixBot
    1. Toshiba SD-K740 Disc Drive Replacement, Disc Drive: step 7, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement, Disc Drive: step 7, image 2 of 2
      • Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
      Ask FixBot
    2. Toshiba SD-K740 Disc Drive Replacement: step 8, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement: step 8, image 2 of 2
      • Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
      Ask FixBot
    3. Toshiba SD-K740 Disc Drive Replacement: step 9, image 1 of 2 Toshiba SD-K740 Disc Drive Replacement: step 9, image 2 of 2
      • Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
      Ask FixBot
    4. Toshiba SD-K740 Disc Drive Replacement: step 10, image 1 of 1
      • Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
      Ask FixBot
    5. Toshiba SD-K740 Disc Drive Replacement: step 11, image 1 of 1
      • Lift disc drive vertically to remove.
      Ask FixBot
2 other people completed this guide.
Joe Murphy
563 Reputation
5 Guides authored
Cal Poly, Team 1-16, Amido Winter 2011 Member of Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 59
All Time: 3,101
