Toshiba NB305 Wifi Card Replacement
    1. Toshiba NB305 Wifi Card Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down with the battery facing you.
      Ask FixBot
    2. Toshiba NB305 Wifi Card Replacement: step 2, image 1 of 1
      • Use your right hand to move latch 1 to the right to unlock the battery.
      Ask FixBot
    3. Toshiba NB305 Wifi Card Replacement: step 3, image 1 of 2 Toshiba NB305 Wifi Card Replacement: step 3, image 2 of 2
      • Use your left hand to hold latch 2 to the left.
      • Simultaneously take the battery out with your right hand.
      Ask FixBot
    1. Toshiba NB305 Wifi Card Replacement, Wifi Card: step 4, image 1 of 3 Toshiba NB305 Wifi Card Replacement, Wifi Card: step 4, image 2 of 3 Toshiba NB305 Wifi Card Replacement, Wifi Card: step 4, image 3 of 3
      • Locate the two torx T-6 screws on the back of the laptop and remove them.
      • 6mm Torx T-6 Screws
      Ask FixBot
    2. Toshiba NB305 Wifi Card Replacement: step 5, image 1 of 2 Toshiba NB305 Wifi Card Replacement: step 5, image 2 of 2
      • Using a spudger pry the panel up.
      Ask FixBot
    3. Toshiba NB305 Wifi Card Replacement: step 6, image 1 of 2 Toshiba NB305 Wifi Card Replacement: step 6, image 2 of 2
      • Using a spudger pry up and off the two wire connections.
      • Note that the black wire is on the top of the card and the white is the bottom.
      Ask FixBot
    4. Toshiba NB305 Wifi Card Replacement: step 7, image 1 of 2 Toshiba NB305 Wifi Card Replacement: step 7, image 2 of 2
      • Remove the two Phillips 0 size screws on WIFI card.
      • Once the screws are removed the WIFI card will raise up
      Ask FixBot
    5. Toshiba NB305 Wifi Card Replacement: step 8, image 1 of 2 Toshiba NB305 Wifi Card Replacement: step 8, image 2 of 2
      • Grip both sides of the wifi card with your hand.
      • Lift up on the card and pull the card out of the slot
      Ask FixBot
Mateo Fontana
307 Reputation
2 Guides authored
USF Tampa, Team 5-5, Lacy Fall 2016 Member of USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 804
