Up to 20% off select tools
Toshiba NB305 RAM Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
91
All Time:
1,346
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
When purchasing a new RAM make sure the computer memory type is DDR2. When working on anything inside of your laptop make sure that you try and avoid any static friction. This will be great for improving your laptops speed while running programs.
    1. Toshiba NB305 RAM  Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down with the battery facing you.
      Ask FixBot
    2. Toshiba NB305 RAM  Replacement: step 2, image 1 of 1
      • Use your right hand to move latch 1 to the right to unlock the battery.
      Ask FixBot
    3. Toshiba NB305 RAM  Replacement: step 3, image 1 of 2 Toshiba NB305 RAM  Replacement: step 3, image 2 of 2
      • Use your left hand to hold latch 2 to the left.
      • Simultaneously take the battery out with your right hand.
      Ask FixBot
    1. Toshiba NB305 RAM  Replacement, RAM: step 4, image 1 of 1
      • The RAM is located underneath the top left panel on the back of the laptop.
      • Remove the captive Phillips-0 screw with a screwdriver.
      Ask FixBot
    2. Toshiba NB305 RAM  Replacement: step 5, image 1 of 2 Toshiba NB305 RAM  Replacement: step 5, image 2 of 2
      • Using a spudger pry up on the open slit next to the screw.
      Ask FixBot
    3. Toshiba NB305 RAM  Replacement: step 6, image 1 of 2 Toshiba NB305 RAM  Replacement: step 6, image 2 of 2
      • The RAM is held in place with two clips, one on each side.
      • Using two plastic opening tools (or your fingers) pull two tabs holding RAM outwards.
      • The RAM card will pop up when it is released.
      Ask FixBot
    4. Toshiba NB305 RAM  Replacement: step 7, image 1 of 2 Toshiba NB305 RAM  Replacement: step 7, image 2 of 2
      • Pull the RAM straight out of the slot.
      Ask FixBot
Author
with
Nuri Chung
377 Reputation
3 Guides authored
USF Tampa, Team 5-5, Lacy Fall 2016 Member of USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 91
All Time: 1,346
