Up to 20% off select tools
Toshiba NB305 Keyboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
91
All Time:
1,466
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
When replacing your keyboard make sure that you are not to rough with the removal of the keyboard. Take your time and go slowly or you will run the risk of damaging the laptop. Replacing your keyboard can help with efficiency and make working on your leptop more productive.
    1. Toshiba NB305 Keyboard  Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down with the battery facing you.
      Ask FixBot
    2. Toshiba NB305 Keyboard  Replacement: step 2, image 1 of 1
      • Use your right hand to move latch 1 to the right to unlock the battery.
      Ask FixBot
    3. Toshiba NB305 Keyboard  Replacement: step 3, image 1 of 2 Toshiba NB305 Keyboard  Replacement: step 3, image 2 of 2
      • Use your left hand to hold latch 2 to the left.
      • Simultaneously take the battery out with your right hand.
      Ask FixBot
    1. Toshiba NB305 Keyboard  Replacement, Keyboard: step 4, image 1 of 2 Toshiba NB305 Keyboard  Replacement, Keyboard: step 4, image 2 of 2
      • Remove the four F4 screws and the F6 screw underneath battery.
      • 4mm Phillips-0 screws.
      • 6mm Phillips-0 screws.
      Ask FixBot
    2. Toshiba NB305 Keyboard  Replacement: step 5, image 1 of 3 Toshiba NB305 Keyboard  Replacement: step 5, image 2 of 3 Toshiba NB305 Keyboard  Replacement: step 5, image 3 of 3
      • Using a spudger, gently pry out on the plastic cover.
      • Turn it over and remove plastic cover on top of laptop with power button on it.
      Ask FixBot
    3. Toshiba NB305 Keyboard  Replacement: step 6, image 1 of 2 Toshiba NB305 Keyboard  Replacement: step 6, image 2 of 2
      • Use the plastic opening tool in little notches above the keyboard
      • Gently pry up on the keyboard until it lifts up.
      • You might hear a click when the keyboard releases.
      Ask FixBot
    4. Toshiba NB305 Keyboard  Replacement: step 7, image 1 of 1
      • Gently lift the keyboard up toward the screen.
      • Be careful! There is a cable still connected from the computer to the keyboard.
      Ask FixBot
    5. Toshiba NB305 Keyboard  Replacement: step 8, image 1 of 2 Toshiba NB305 Keyboard  Replacement: step 8, image 2 of 2
      • The ribbon cable has a clip on each side holding it to the motherboard.
      • Using a spudger, press on the clips to release the cable.
      • The cable will slide out on its own when it is properly released.
      Ask FixBot
Author
with
Nuri Chung
377 Reputation
3 Guides authored
USF Tampa, Team 5-5, Lacy Fall 2016 Member of USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 91
All Time: 1,466
