Toshiba NB255-N250 Memory Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
12
Past 30 Days:
63
All Time:
983
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: step 1, image 1 of 2 Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: step 1, image 2 of 2
      • Before starting any repairs, make sure to power off your device.
      • To shut down the Toshiba NB255-N250, follow the instructions for your operating system or press and hold the power button until the screen turns off.
      Ask FixBot
    2. Toshiba NB255-N250 Memory Replacement, Remove the Battery: step 2, image 1 of 3 Toshiba NB255-N250 Memory Replacement, Remove the Battery: step 2, image 2 of 3 Toshiba NB255-N250 Memory Replacement, Remove the Battery: step 2, image 3 of 3
      • Move the two battery retaining tabs to the opposite sides of the device, then pull the battery straight out the back of the device.
      Ask FixBot
    1. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel Screw: step 3, image 1 of 1
      • Remove the PH1 screw from the memory access panel.
      • Unlike many other access cover screws on laptops, this screw is not captive.
      Ask FixBot
    2. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel: step 4, image 1 of 1
      • Use a Metal Spudger or other opening tool to remove the memory access panel.
      Ask FixBot
    3. Toshiba NB255-N250 Memory Replacement, Remove Old Memory: step 5, image 1 of 2 Toshiba NB255-N250 Memory Replacement, Remove Old Memory: step 5, image 2 of 2
      • Remove the memory by moving the tabs on the left and right away from the ram.
      • When fully opened, the memory will pop up at a 45 degree angle. Pull the memory straight out by the sides and away from the system.
      Ask FixBot
4 other people completed this guide.
Charles Myrick
342 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 63
All Time: 983
