Toshiba NB205 N330PK RAM Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
88
All Time:
1,061
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. Toshiba NB205 N330PK RAM Replacement, RAM: step 1, image 1 of 2 Toshiba NB205 N330PK RAM Replacement, RAM: step 1, image 2 of 2
      • Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
      • Lift the panel up and out of the way.
      Ask FixBot
    2. Toshiba NB205 N330PK RAM Replacement: step 2, image 1 of 3 Toshiba NB205 N330PK RAM Replacement: step 2, image 2 of 3 Toshiba NB205 N330PK RAM Replacement: step 2, image 3 of 3
      • The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
      • After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
      Ask FixBot
    3. Toshiba NB205 N330PK RAM Replacement: step 3, image 1 of 2 Toshiba NB205 N330PK RAM Replacement: step 3, image 2 of 2
      • Push the replacement RAM into the original position.
      • Reattach both securing arms onto the sides of the RAM chip.
      Ask FixBot
    4. Toshiba NB205 N330PK RAM Replacement: step 4, image 1 of 2 Toshiba NB205 N330PK RAM Replacement: step 4, image 2 of 2
      • Place the panel back into the securing slots and let it rest in its original position.
      • With the bit driver and Phillips #0 bit, secure the panel down with one screw.
      Ask FixBot
Mason McCaskill
1,021 Reputation
9 Guides authored
Clemson, Team 14-2, Benson Fall 2013 Member of Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 88
All Time: 1,061
