Toshiba Mini NB505 WiFi Card Replacement
    1. Toshiba Mini NB505 WiFi Card Replacement, Bottom Plate: step 1, image 1 of 1
      • Locate the two 1.2mm philips #000 screws holding the bottom plate onto the laptop.
      Ask FixBot
    2. Toshiba Mini NB505 WiFi Card Replacement: step 2, image 1 of 1
      • Using a Philips head #000 screwdriver, carefully remove the two 1.2mm screws.
      Ask FixBot
    3. Toshiba Mini NB505 WiFi Card Replacement: step 3, image 1 of 1
      • The plate can now be easily removed.
      Ask FixBot
    1. Toshiba Mini NB505 WiFi Card Replacement, WiFi Card: step 4, image 1 of 1
      • Locate the WiFi card by following the black and white wiring inside of the laptop.
      Ask FixBot
    2. Toshiba Mini NB505 WiFi Card Replacement: step 5, image 1 of 2 Toshiba Mini NB505 WiFi Card Replacement: step 5, image 2 of 2
      • Locate and gently pull up on the black and white wires connecting to the card.
      Ask FixBot
    3. Toshiba Mini NB505 WiFi Card Replacement: step 6, image 1 of 1
      • Locate the two 1.2 mm phillips #000 screws holding the WiFi card.
      Ask FixBot
    4. Toshiba Mini NB505 WiFi Card Replacement: step 7, image 1 of 1
      • Use a Phillips head #000 screwdriver to remove the two 1.2mm screws holding the card into the laptop.
      Ask FixBot
    5. Toshiba Mini NB505 WiFi Card Replacement: step 8, image 1 of 1
      • Once the card pops up, gentle remove it.
      Ask FixBot
4 other people completed this guide.
Owen Velho
562 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 102
All Time: 1,506
