Toshiba Excite 7c Screen Replacement
    1. Toshiba Excite 7c Screen Replacement, Motherboard: step 1, image 1 of 2 Toshiba Excite 7c Screen Replacement, Motherboard: step 1, image 2 of 2
      • Place an iFixit opening tool in the seam between the screen and back casing.
      • Apply pressure down all four sides to separate the back casing from the screen.
      • Place the tablet face down and carefully remove the back panel.
      Ask FixBot
    2. Toshiba Excite 7c Screen Replacement: step 2, image 1 of 2 Toshiba Excite 7c Screen Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Use a Phillips screwdriver to remove the five 6 mm screws from the motherboard.
      • Use tweezers to gently disconnect the two ribbon cables.
      • Pull straight up to remove the board.
      Ask FixBot
    1. Toshiba Excite 7c Screen Replacement, Screen: step 3, image 1 of 1
      • With all of the components removed continue with reassembly using a new screen as the base for reassembly.
      Ask FixBot
Reyna Serrato
96 Reputation
5 Guides authored
Gateway, Team 1-2, Johnson Fall 2014 Member of Gateway, Team 1-2, Johnson Fall 2014
GCC-JOHNSON-F14S1G2
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 86
All Time: 710
