Toshiba Excite 7c Battery Replacement
    1. Toshiba Excite 7c Battery Replacement, Open  Device: step 1, image 1 of 2 Toshiba Excite 7c Battery Replacement, Open  Device: step 1, image 2 of 2
      • To open your device use the plastic opener. Locate the seam on your device and gently separate applying pressure down all four sides.
      • The back casing will start to peel away from the screen.
      • Carefully lift and remove the back panel with tablet lying face down on table. this will reveal the back side.
      Ask FixBot
    2. Toshiba Excite 7c Battery Replacement, Remove Battery: step 2, image 1 of 3 Toshiba Excite 7c Battery Replacement, Remove Battery: step 2, image 2 of 3 Toshiba Excite 7c Battery Replacement, Remove Battery: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Locate the battery on the back of your device.
      • Remove the battery connector using a pair of tweezers.
      • On the side of the battery peel back but do not remove the two black pieces of tape.
      • Remove just to the white line NOT completely.
      • Carefully lift the battery out of the device, and set aside.
      Ask FixBot
3 other people completed this guide.
Reyna Serrato
96 Reputation
5 Guides authored
Gateway, Team 1-2, Johnson Fall 2014 Member of Gateway, Team 1-2, Johnson Fall 2014
GCC-JOHNSON-F14S1G2
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 91
All Time: 1,103
