Toshiba Excite 7 Screen Replacement
    1. Toshiba Excite 7 Screen Replacement, Battery: step 1, image 1 of 3 Toshiba Excite 7 Screen Replacement, Battery: step 1, image 2 of 3 Toshiba Excite 7 Screen Replacement, Battery: step 1, image 3 of 3
      • Remove the back cover.
      • Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
      • After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
      Ask FixBot
    2. Toshiba Excite 7 Screen Replacement: step 2, image 1 of 2 Toshiba Excite 7 Screen Replacement: step 2, image 2 of 2
      • Remove any black tape from the device.
      • Keep the tape; you will need to put it back on when you are done.
      Ask FixBot
    3. Toshiba Excite 7 Screen Replacement, Unplug Wires: step 3, image 1 of 2 Toshiba Excite 7 Screen Replacement, Unplug Wires: step 3, image 2 of 2
      • Unplug the wires from the battery.
      • The battery is the black rectangle in the middle of the device. The device has two wiring harnesses attached to it: one just above the battery and one just to the right.
      Ask FixBot
    4. Toshiba Excite 7 Screen Replacement, remove screws: step 4, image 1 of 2 Toshiba Excite 7 Screen Replacement, remove screws: step 4, image 2 of 2
      • Remove the five screws from the battery.
      Ask FixBot
    5. Toshiba Excite 7 Screen Replacement: step 5, image 1 of 2 Toshiba Excite 7 Screen Replacement: step 5, image 2 of 2
      • The battery has one clip you will need to remove. The clip is located at the bottom right corner of the battery just above the right speaker. The speakers and wires are not secured to the battery; they may fall off.
      • Push the clip back then lift the battery up.
      Ask FixBot
    1. Toshiba Excite 7 Screen Replacement, Remove Data cable: step 6, image 1 of 1
      • The screen is connected to the circuit board by 2 “Data Cables” (orange ribbons). Data cables include 3 working components, data cables, the white harness plug, and the black lever.
      • Gently flip the black lever up and unplug data cables.
      Ask FixBot
    2. Toshiba Excite 7 Screen Replacement, Removing the Circuit Board: step 7, image 1 of 1
      • Remove the circuit board by gently coaxing it from the clips located just to the right of the circuit board.
      Ask FixBot
    3. Toshiba Excite 7 Screen Replacement, Installing the Replacement Screen Assembly: step 8, image 1 of 2 Toshiba Excite 7 Screen Replacement, Installing the Replacement Screen Assembly: step 8, image 2 of 2
      • The screen has a rubber device used to support the volume control switch.
      • Remove the rubber device from the old screen.
      • Make sure you keep the rubber device to be install into the new screen.
      • Repeat other steps in reverse to install replacement screen.
      Ask FixBot
Sean Ulch
340 Reputation
3 Guides authored
USF Tampa, Team 1-3, Tanski Winter 2015 Member of USF Tampa, Team 1-3, Tanski Winter 2015
USFT-TANSKI-W15S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 103
All Time: 1,829
