Toshiba Equium M70 Faulty Graphics
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
99
All Time:
2,570
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 hours
Difficulty: Moderate
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Community-Contributed Guide
Introduction
Go to step 1 ↓
The fix, I place a thin alloy shim between the existing heatsink & chip, with a good quality thermal paste, I always use artic silver 5(never lets you down)
Tools
    1. Toshiba Equium M70 Faulty Graphics, Toshiba Equium M70 Faulty Graphics: step 1, image 1 of 1
      • This is a complete top half strip down to fix (takes me less than 30 minutes)
      Ask FixBot
    2. Toshiba Equium M70 Faulty Graphics: step 2, image 1 of 1
      • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
      Ask FixBot
    3. Toshiba Equium M70 Faulty Graphics: step 3, image 1 of 1
      • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
      Ask FixBot
    4. Toshiba Equium M70 Faulty Graphics: step 4, image 1 of 1
      • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
      Ask FixBot
    5. Toshiba Equium M70 Faulty Graphics: step 5, image 1 of 1
      • THen apply more thermal paste to the top of the shim
      Ask FixBot
    6. Toshiba Equium M70 Faulty Graphics: step 6, image 1 of 1
      • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
      Ask FixBot
    7. Toshiba Equium M70 Faulty Graphics: step 7, image 1 of 1
      • This is the CPU with the new alloy shim fitted.
      Ask FixBot
3 other people completed this guide.
Terry Sim
207 Reputation
1 Guide authored
1 Guide Comment
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 99
All Time: 2,570
