Toshiba Encore WT8-A Battery Replacement
  1. Toshiba Encore WT8-A Battery Replacement, Battery: step 1, image 1 of 1
    • Use the metal spudger to create a gap between the back cover and the device.
    • Be gentle when using the metal spudger so that the casing is not damaged.
    Ask FixBot
  2. Toshiba Encore WT8-A Battery Replacement: step 2, image 1 of 2 Toshiba Encore WT8-A Battery Replacement: step 2, image 2 of 2
    • Use the nylon spudger to completely separate the back of the device.
    • Take the nylon spudger around the outside of the device cover until it comes free.
    Ask FixBot
  3. Toshiba Encore WT8-A Battery Replacement: step 3, image 1 of 2 Toshiba Encore WT8-A Battery Replacement: step 3, image 2 of 2
    • Use the Phillips head PH0 to remove the 7 battery screws.
    • The 5 side screws measure 3.5mm.
    • The 2 top and bottom screws measure 4.5 mm.
    Ask FixBot
  4. Toshiba Encore WT8-A Battery Replacement: step 4, image 1 of 2 Toshiba Encore WT8-A Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • To disconnect the cable, use the fine tweezers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • The zero insertion force (ZIF) connector is used to secure delicate ribbon cables, such as this trackpad cable.
    Ask FixBot
  5. Toshiba Encore WT8-A Battery Replacement: step 5, image 1 of 1
    • Remove the colored power cable from its connector.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Be sure to be very gentle when prying colored wires from motherboard to ensure that there is no damage.
    Ask FixBot
  6. Toshiba Encore WT8-A Battery Replacement: step 6, image 1 of 1
    • Battery will lift out of the device.
    Ask FixBot
2 other people completed this guide.
Zachary Armstrong
293 Reputation
2 Guides authored
USF Tampa, Team 17-4, Blackwell Fall 2016 Member of USF Tampa, Team 17-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G4
3 Members
8 Guides authored
3 Guide Comments
Hi can I get Battery for Toshiba Encore 2 WT8-B?
Thanks
Regards
Dr Ravindra
Ravindra MIstry - Reply Share
Hi friends can I get Battery for Toshiba Encore 2 WT8-B
Thanks
Regards
Dr Ravindra
who can I replacement socket charging for toshiba tablet WT8-A
monzer daoud - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 62
All Time: 5,716
