Toshiba Encore Mini Speakers Replacement
  1. Toshiba Encore Mini Speakers Replacement, Battery: step 1, image 1 of 2 Toshiba Encore Mini Speakers Replacement, Battery: step 1, image 2 of 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
    Ask FixBot
  2. Toshiba Encore Mini Speakers Replacement: step 2, image 1 of 1
    • Remove the rear cover and set it aside.
    Ask FixBot
  3. Toshiba Encore Mini Speakers Replacement: step 3, image 1 of 1
    • Carefully remove the electrical tape that holds the battery in place.
    Ask FixBot
  4. Toshiba Encore Mini Speakers Replacement: step 4, image 1 of 2 Toshiba Encore Mini Speakers Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
    Ask FixBot
  5. Toshiba Encore Mini Speakers Replacement: step 5, image 1 of 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
    Ask FixBot
  6. Toshiba Encore Mini Speakers Replacement, Speakers: step 6, image 1 of 1
    • Use the spudger to pull the speaker wire plug from its socket.
    Ask FixBot
  7. Toshiba Encore Mini Speakers Replacement: step 7, image 1 of 1
    • Carefully use the metal spudger to remove the speaker from the frame of the phone.
    • The speaker is attached with some double-sided adhesive and may be difficult to remove.
    Ask FixBot
Khaled Alsaghayer
101 Reputation
1 Guide authored
IUPUI, Team S5-G5, Wilson Spring 2017 Member of IUPUI, Team S5-G5, Wilson Spring 2017
IUPUI-WILSON-S17S5G5
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 302
