Toshiba Encore Mini Front-Facing Camera Replacement
    1. Toshiba Encore Mini Front-Facing Camera Replacement, Battery: step 1, image 1 of 2 Toshiba Encore Mini Front-Facing Camera Replacement, Battery: step 1, image 2 of 2
      • To replace the battery, the rear cover must first be removed.
      • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
      • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
      Ask FixBot
    2. Toshiba Encore Mini Front-Facing Camera Replacement: step 2, image 1 of 1
      • Remove the rear cover and set it aside.
      Ask FixBot
    3. Toshiba Encore Mini Front-Facing Camera Replacement: step 3, image 1 of 1
      • Carefully remove the electrical tape that holds the battery in place.
      Ask FixBot
    4. Toshiba Encore Mini Front-Facing Camera Replacement: step 4, image 1 of 2 Toshiba Encore Mini Front-Facing Camera Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
      Ask FixBot
    5. Toshiba Encore Mini Front-Facing Camera Replacement: step 5, image 1 of 1
      • Gently lift the battery out of the device.
      • Be careful not to pull on the connecting wires.
      Ask FixBot
    1. Toshiba Encore Mini Front-Facing Camera Replacement, Front-Facing Camera: step 6, image 1 of 3 Toshiba Encore Mini Front-Facing Camera Replacement, Front-Facing Camera: step 6, image 2 of 3 Toshiba Encore Mini Front-Facing Camera Replacement, Front-Facing Camera: step 6, image 3 of 3
      Buy
      • The audio module must be removed to replace the front-facing camera.
      • Using needle-nose tweezers, carefully push the small white wire connector (red/black wires) out of its housing.
      • Gently remove red/black wire strands from the clips holding them to the back of the screen.
      Ask FixBot
    2. Toshiba Encore Mini Front-Facing Camera Replacement: step 7, image 1 of 2 Toshiba Encore Mini Front-Facing Camera Replacement: step 7, image 2 of 2
      • Gently pry audio module from the back of the screen using tweezers and spudger. Be careful not to pull on the wires.
      • Adhesive on the bottom of the speaker module may make it difficult to remove.
      • Set the audio module and attached wire aside.
      Ask FixBot
    3. Toshiba Encore Mini Front-Facing Camera Replacement: step 8, image 1 of 3 Toshiba Encore Mini Front-Facing Camera Replacement: step 8, image 2 of 3 Toshiba Encore Mini Front-Facing Camera Replacement: step 8, image 3 of 3
      • Using needle-nose tweezers, carefully flip up the dark gray cover on the right of the device holding the small orange ribbon in place. (It is approximately 1/4" wide.)
      • With the tweezers, carefully pull the small ribbon out of its housing. It will stay attached to the device at the other end.
      Ask FixBot
    4. Toshiba Encore Mini Front-Facing Camera Replacement: step 9, image 1 of 2 Toshiba Encore Mini Front-Facing Camera Replacement: step 9, image 2 of 2
      • A wide orange/gold ribbon connects the screen to the motherboard. (Ribbon is approximately 1" wide.)
      • Carefully pull the black tape off the ribbon housing and set it aside. You will need to replace the tape when reassembling the device.
      Ask FixBot
    5. Toshiba Encore Mini Front-Facing Camera Replacement: step 10, image 1 of 3 Toshiba Encore Mini Front-Facing Camera Replacement: step 10, image 2 of 3 Toshiba Encore Mini Front-Facing Camera Replacement: step 10, image 3 of 3
      • Damaging this ribbon will permanently disable your device!
      • Using needle-nose tweezers, carefully flip up the dark gray cover.
      • With the tweezers, carefully pull the wide ribbon from its housing. It will stay attached to the device at the other end.
      Ask FixBot
    6. Toshiba Encore Mini Front-Facing Camera Replacement: step 11, image 1 of 3 Toshiba Encore Mini Front-Facing Camera Replacement: step 11, image 2 of 3 Toshiba Encore Mini Front-Facing Camera Replacement: step 11, image 3 of 3
      • Using a Phillips 000 screwdriver, remove the screws holding components together.
      • Remove four 4.2 mm Phillips screws.
      • Remove one 3mm Phillips screw.
      Ask FixBot
    7. Toshiba Encore Mini Front-Facing Camera Replacement: step 12, image 1 of 2 Toshiba Encore Mini Front-Facing Camera Replacement: step 12, image 2 of 2
      • Holding the motherboard carefully by the edges, gently lift it up off the screen and carefully set it aside.
      • The motherboard may resist as you try to lift it --this is normal.
      Ask FixBot
    8. Toshiba Encore Mini Front-Facing Camera Replacement: step 13, image 1 of 2 Toshiba Encore Mini Front-Facing Camera Replacement: step 13, image 2 of 2
      • The front-facing camera may dislodge freely when removing the motherboard.
      • If camera has not already "popped" off the motherboard, use needle-nose tweezers to gently grasp the camera and remove from motherboard.
      Ask FixBot
Shirley Low
143 Reputation
1 Guide authored
UW Tacoma, Team 1-3, Liner SU 2015 Member of UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 96
All Time: 849
