Toshiba Encore Mini Battery Replacement
    1. Toshiba Encore Mini Battery Replacement, Battery: step 1, image 1 of 2 Toshiba Encore Mini Battery Replacement, Battery: step 1, image 2 of 2
      • To replace the battery, the rear cover must first be removed.
      • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
      • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
      Ask FixBot
    2. Toshiba Encore Mini Battery Replacement: step 2, image 1 of 1
      • Remove the rear cover and set it aside.
      Ask FixBot
    3. Toshiba Encore Mini Battery Replacement: step 3, image 1 of 1
      • Carefully remove the electrical tape that holds the battery in place.
      Ask FixBot
    4. Toshiba Encore Mini Battery Replacement: step 4, image 1 of 2 Toshiba Encore Mini Battery Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
      Ask FixBot
    5. Toshiba Encore Mini Battery Replacement: step 5, image 1 of 1
      • Gently lift the battery out of the device.
      • Be careful not to pull on the connecting wires.
      Ask FixBot
5 other people completed this guide.
Erica Jouglard
263 Reputation
1 Guide authored
UW Tacoma, Team 1-3, Liner SU 2015 Member of UW Tacoma, Team 1-3, Liner SU 2015
UWT-LINER-SU15S1G3
4 Members
36 Guides authored
2 Guide Comments
Be sure to remove any SD cards you have first.
ecw0647 - Reply Share
But where do i buy the battery?
sissyhana - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 90
All Time: 4,611
