Toshiba Dynabook AX 53D Keyboard Replacement
    1. Toshiba Dynabook AX 53D Keyboard  Replacement, Battery: step 1, image 1 of 1
      • Push apart the two spring loaded plastic tabs labeled #1 and #2.
      • Make sure to unplug any external power sources before working on the computer.
      Ask FixBot
    2. Toshiba Dynabook AX 53D Keyboard  Replacement: step 2, image 1 of 1
      • The battery is now easily removed by pulling up from the notched tab on the inside edge.
      Ask FixBot
    1. Toshiba Dynabook AX 53D Keyboard  Replacement, Keyboard: step 3, image 1 of 1
      • Using the #J1 bit, remove the 17 recessed 7.3 mm B6 screws from the underside of laptop and the 3.1 mm #J0 F3 screw inside the battery compartment.
      Ask FixBot
    2. Toshiba Dynabook AX 53D Keyboard  Replacement: step 4, image 1 of 2 Toshiba Dynabook AX 53D Keyboard  Replacement: step 4, image 2 of 2
      • Run the blue plastic opening tool underneath the media bezel and gently pry from the front panel.
      Ask FixBot
    3. Toshiba Dynabook AX 53D Keyboard  Replacement: step 5, image 1 of 1
      • Using the #J0 bit, remove the two 3.1 mm screws securing the top of the keyboard.
      Ask FixBot
    4. Toshiba Dynabook AX 53D Keyboard  Replacement: step 6, image 1 of 2 Toshiba Dynabook AX 53D Keyboard  Replacement: step 6, image 2 of 2
      • Pop out the black plastic tab on either side of the ribbon cable. Holding the cable on each side, detach from laptop.
      Ask FixBot
Christopher
525 Reputation
5 Guides authored
1 Guide Comment
لو يكون عملي فيديو لكان افضل
nour - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 99
All Time: 1,765
