Toshiba Chromebook 2 Touchpad Replacement
  1. Toshiba Chromebook 2 Touchpad Replacement, Back Cover: step 1, image 1 of 1
    • Remove all external devices from the Toshiba Chromebook 2.
    Ask FixBot
  2. Toshiba Chromebook 2 Touchpad Replacement: step 2, image 1 of 1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
    Ask FixBot
  3. Toshiba Chromebook 2 Touchpad Replacement: step 3, image 1 of 2 Toshiba Chromebook 2 Touchpad Replacement: step 3, image 2 of 2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
    Ask FixBot
  4. Toshiba Chromebook 2 Touchpad Replacement: step 4, image 1 of 2 Toshiba Chromebook 2 Touchpad Replacement: step 4, image 2 of 2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
    Ask FixBot
  5. Toshiba Chromebook 2 Touchpad Replacement: step 5, image 1 of 1
    • Remove the back panel by pulling up on 2 adjacent corners.
    Ask FixBot
  6. Toshiba Chromebook 2 Touchpad Replacement, Battery: step 6, image 1 of 2 Toshiba Chromebook 2 Touchpad Replacement, Battery: step 6, image 2 of 2
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
    Ask FixBot
  7. Toshiba Chromebook 2 Touchpad Replacement: step 7, image 1 of 2 Toshiba Chromebook 2 Touchpad Replacement: step 7, image 2 of 2
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
    Ask FixBot
  8. Toshiba Chromebook 2 Touchpad Replacement: step 8, image 1 of 1
    • Remove the battery by gently pulling up on the bottom corners.
    Ask FixBot
  9. Toshiba Chromebook 2 Touchpad Replacement, Speakers: step 9, image 1 of 1
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
    Ask FixBot
  10. Toshiba Chromebook 2 Touchpad Replacement: step 10, image 1 of 3 Toshiba Chromebook 2 Touchpad Replacement: step 10, image 2 of 3 Toshiba Chromebook 2 Touchpad Replacement: step 10, image 3 of 3
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
    Ask FixBot
  11. Toshiba Chromebook 2 Touchpad Replacement: step 11, image 1 of 1
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
    Ask FixBot
  12. Toshiba Chromebook 2 Touchpad Replacement, Touchpad: step 12, image 1 of 2 Toshiba Chromebook 2 Touchpad Replacement, Touchpad: step 12, image 2 of 2
    • Detach the ribbon cable connected to the motherboard by gently pulling near the top fold.
    Ask FixBot
  13. Toshiba Chromebook 2 Touchpad Replacement: step 13, image 1 of 1
    • Detach the ribbon cable connected to the touch pad by gently pulling near the bottom fold.
    Ask FixBot
  14. Toshiba Chromebook 2 Touchpad Replacement: step 14, image 1 of 2 Toshiba Chromebook 2 Touchpad Replacement: step 14, image 2 of 2
    • Remove all four 3.70mm screws around the edges of the touchpad using a Phillips #0 screwdriver.
    Ask FixBot
  15. Toshiba Chromebook 2 Touchpad Replacement: step 15, image 1 of 2 Toshiba Chromebook 2 Touchpad Replacement: step 15, image 2 of 2
    • Use the spudger to push up on the metal cover below the touch pad until it reaches 90 degrees then pull up to detach.
    Ask FixBot
  16. Toshiba Chromebook 2 Touchpad Replacement: step 16, image 1 of 3 Toshiba Chromebook 2 Touchpad Replacement: step 16, image 2 of 3 Toshiba Chromebook 2 Touchpad Replacement: step 16, image 3 of 3
    • Peel back the aluminum foil piece on the top right corner of the touchpad.
    • Move slowly and carefully, you will need the same aluminum foil piece to connect to your new touchpad.
    Ask FixBot
  17. Toshiba Chromebook 2 Touchpad Replacement: step 17, image 1 of 2 Toshiba Chromebook 2 Touchpad Replacement: step 17, image 2 of 2
    • Push down on the bottom right corner and slowly lift up in the upper right hand corner until the touch pad comes out.
    Ask FixBot
4 other people completed this guide.
Haley Hattendorf
598 Reputation
2 Guides authored
Cal Poly, Team 10-4, Livingston Fall 2016 Member of Cal Poly, Team 10-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G4
4 Members
11 Guides authored
2 Guide Comments
Thanks for this guide! Worked perfectly.
Mathias Maes - Reply Share
This is great! I was able to save our school the cost of a replacement computer!
Tiger Prior - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 2,138
