Toshiba A1304T Keypad Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
85
All Time:
2,250
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Use this guide to replace your Toshiba AT1304T keypad
Parts
Tools
    1. Toshiba A1304T Keypad Replacement, Back panel: step 1, image 1 of 1
      • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
      Ask FixBot
    2. Toshiba A1304T Keypad Replacement: step 2, image 1 of 1
      • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
      • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
      Ask FixBot
    3. Toshiba A1304T Keypad Replacement: step 3, image 1 of 2 Toshiba A1304T Keypad Replacement: step 3, image 2 of 2
      • If needed, use the flathead screwdriver to gently pry the panel from the phone.
      • Using your fingers, lift the panel from the device.
      Ask FixBot
    1. Toshiba A1304T Keypad Replacement, Keypad: step 4, image 1 of 3 Toshiba A1304T Keypad Replacement, Keypad: step 4, image 2 of 3 Toshiba A1304T Keypad Replacement, Keypad: step 4, image 3 of 3
      • Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
      Ask FixBot
    2. Toshiba A1304T Keypad Replacement: step 5, image 1 of 2 Toshiba A1304T Keypad Replacement: step 5, image 2 of 2
      • Use a flathead screwdriver to gently pry the logic board and keypad from the device.
      Ask FixBot
    3. Toshiba A1304T Keypad Replacement: step 6, image 1 of 2 Toshiba A1304T Keypad Replacement: step 6, image 2 of 2
      • Peel the keypad from the logic board using your thumb.
      Ask FixBot
Christopher
90 Reputation
8 Guides authored
Cal Poly, Team 16-6, Maness Spring 2010 Member of Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 85
All Time: 2,250
