Toshiba A1304T Camera Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
95
All Time:
2,680
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Use this guide to replace the Toshiba A1304T camera.
Parts
Tools
    1. Toshiba A1304T Camera Replacement, Back panel: step 1, image 1 of 1
      • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
      Ask FixBot
    2. Toshiba A1304T Camera Replacement: step 2, image 1 of 1
      • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
      • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
      Ask FixBot
    3. Toshiba A1304T Camera Replacement: step 3, image 1 of 2 Toshiba A1304T Camera Replacement: step 3, image 2 of 2
      • If needed, use the flathead screwdriver to gently pry the panel from the phone.
      • Using your fingers, lift the panel from the device.
      Ask FixBot
    1. Toshiba A1304T Camera Replacement, Camera: step 4, image 1 of 2 Toshiba A1304T Camera Replacement, Camera: step 4, image 2 of 2
      • Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
      • Gently pull the silver plate from the phone using your fingers.
      Ask FixBot
    2. Toshiba A1304T Camera Replacement: step 5, image 1 of 3 Toshiba A1304T Camera Replacement: step 5, image 2 of 3 Toshiba A1304T Camera Replacement: step 5, image 3 of 3
      • Using the head of a flathead screwdriver, flip the white segment of the socket that the camera's ribbon-wire runs into so that it is orientated vertically.
      • Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger.
      Ask FixBot
Christopher
90 Reputation
8 Guides authored
Cal Poly, Team 16-6, Maness Spring 2010 Member of Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 95
All Time: 2,680
