Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement
    1. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Disconnect the spark plug wire: step 1, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Disconnect the spark plug wire: step 1, image 2 of 2
      • Before you begin, ensure that the engine is powered down and cool to the touch.
      • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
      Ask FixBot
    2. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Flip the engine switch to the off position: step 2, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Flip the engine switch to the off position: step 2, image 2 of 2
      • Flip the red engine ON/OFF switch to the OFF position.
      Ask FixBot
    3. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Close the fuel valve: step 3, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Close the fuel valve: step 3, image 2 of 2
      • Flip the fuel valve lever to the OFF position.
      Ask FixBot
    1. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the control valve bracket bolts: step 4, image 1 of 1
      • Use a 3/8 inch socket to remove the three bolts securing the control valve to the control valve bracket.
      Ask FixBot
    2. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 5, image 1 of 1
      • Use a 9/16 inch socket to remove the two bolts securing the control valve bracket to the frame.
      Ask FixBot
    3. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the control valve bracket: step 6, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the control valve bracket: step 6, image 2 of 2
      • Remove the control valve bracket.
      Ask FixBot
    1. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Prepare for fluid drips: step 7, image 1 of 1
      • Residual hydraulic fluid will be trapped in the hoses connected to the control valve, and may drip during the following procedure.
      • Place a bucket underneath the device, below the control valve to catch any hydraulic fluid drips.
      • Have rags handy to stop drips and clean up affected areas.
      Ask FixBot
    2. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose: step 8, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose: step 8, image 2 of 2
      • Use an adjustable wrench to loosen the nut securing the output hose to the L-fitting on top of the control valve.
      Ask FixBot
    3. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 9, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 9, image 2 of 2
      • Remove the output hose from the top L-fitting.
      Ask FixBot
    4. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose: step 10, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose: step 10, image 2 of 2
      • Use an adjustable wrench to loosen the nut holding the input hose to the L-fitting on the bottom of the control valve.
      Ask FixBot
    5. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 11, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 11, image 2 of 2
      • Remove the input hose from the bottom L-fitting.
      Ask FixBot
    6. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the top L-fitting: step 12, image 1 of 1
      • Use an adjustable wrench to loosen the nut securing the top L-fitting to the control valve.
      Ask FixBot
    7. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 13, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 13, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 13, image 3 of 3
      • Spin the top L-fitting counter-clockwise to remove it.
      • This fitting is part number 340-16.
      Ask FixBot
    8. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the bottom L-fitting: step 14, image 1 of 1
      • Use an adjustable wrench to loosen the nut securing the bottom L-fitting to the control valve.
      Ask FixBot
    9. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 15, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 15, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 15, image 3 of 3
      • Remove the bottom L-fitting.
      Ask FixBot
    10. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the piston extension hose: step 16, image 1 of 1
      • Use an adjustable wrench to loosen the nut securing the piston extension hose to the L-fitting on the rear of the control valve.
      Ask FixBot
    11. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 17, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 17, image 2 of 2
      • Remove the piston extension hose from the rear L-fitting.
      Ask FixBot
    12. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the control valve: step 18, image 1 of 1
      • Use an adjustable wrench to loosen the nut securing the control valve to the cylinder.
      • This connection is the last part holding the control valve to the device, so keep the control valve supported during removal.
      Ask FixBot
    13. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 19, image 1 of 2 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 19, image 2 of 2
      • Remove the control valve.
      Ask FixBot
    14. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove leftover fittings: step 20, image 1 of 1
      • Use an adjustable wrench to loosen the nut securing the piston contraction fitting to the control valve.
      Ask FixBot
    15. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 21, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 21, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 21, image 3 of 3
      • Spin the piston contraction fitting counter-clockwise to remove it.
      • This fitting is part number 100-7671.
      Ask FixBot
    16. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 22, image 1 of 1
      • Use an adjustable wrench to loosen the nut securing the L-fitting to the rear of the control valve.
      Ask FixBot
    17. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 23, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 23, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 23, image 3 of 3
      • Spin the L-fitting counter-clockwise to remove it.
      • This fitting is part number 340-98.
      Ask FixBot
    18. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement: step 24, image 1 of 1
      • Only the control valve remains.
      Ask FixBot
    1. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose fitting O-ring: step 25, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose fitting O-ring: step 25, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the output hose fitting O-ring: step 25, image 3 of 3
      • Use a pick tool to remove the O-ring from the output hose L-fitting, on the side that connects to the control valve.
      • This O-ring is part number 237-80.
      • The O-ring between the L-fitting and the hose is part number 237-58. Only replace this O-ring if it is visibly damaged.
      Ask FixBot
    2. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose fitting O-ring: step 26, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose fitting O-ring: step 26, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the input hose fitting O-ring: step 26, image 3 of 3
      • Use a pick tool to remove the O-ring from the input hose L-fitting, on the side that connects to the control valve.
      Ask FixBot
    3. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder contraction fitting O-ring: step 27, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder contraction fitting O-ring: step 27, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder contraction fitting O-ring: step 27, image 3 of 3
      • Use a pick tool to remove the O-ring from the cylinder contraction fitting, on the side that connects to the control valve.
      • This O-ring is part number 237-79.
      • The O-ring between the L-fitting and the hose is part number 237-30. Only replace this O-ring if it is visibly damaged.
      Ask FixBot
    4. Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder extension fitting O-ring: step 28, image 1 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder extension fitting O-ring: step 28, image 2 of 3 Toro Log Splitters 22618HD 2019 Control Valve O-Rings Replacement, Remove the cylinder extension fitting O-ring: step 28, image 3 of 3
      • Use a pick tool to remove the O-ring from the cylinder extension hose L-fitting, on the side that connects to the control valve.
      Ask FixBot
Carsten Frauenheim
168,848 Reputation
437 Guides authored
iFixit Member of iFixit
Staff
123 Members
74,524 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 605
