Introduction
I'm about to show you how to change the blade on a Toro 22-inch Recycler lawnmower. It's a relatively simple process that should take only a few minutes. A socket wrench with a 5/8-inch bit, and a brick or a piece of wood are all that's required. Just make sure to drain the gas, put the lawnmower on its side, stabilize the blade, and unhook the sparkplug wire. It's important to unhook the sparkplug wire so the engine has no chance of starting. In only a few minutes, your Toro lawnmower will be producing a well-manicured lawn on a hot, sunny summer afternoon. Lawnmower users need to change the blade once every two years. You'll know when to change it when the blade looks dull or bent, and dents or gouges appear.
Place the lawnmower on its side.
Drain the gas, and make sure the lawnmower is tilted so the oil dip stick is down.
2 other people completed this guide.
