Toro 22-Inch Recycler Lawn Mower Blade Replacement
    1. Toro 22-Inch Recycler Lawn Mower Blade Replacement, Put the Mower on Its Side: step 1, image 1 of 1
      • Put the lawnmower on its side, drain the gas, and make sure the lawnmower is tilted so the oil dip stick is down, preventing the oil from seeping into the air filter.
      Ask FixBot
    2. Toro 22-Inch Recycler Lawn Mower Blade Replacement, Remove the Sparkplug Wire from the Sparkplug: step 2, image 1 of 1
      • It's important to remove the sparkplug wire from the sparkplug so there's no chance that the lawnmower starts during the removal process.
      Ask FixBot
    3. Toro 22-Inch Recycler Lawn Mower Blade Replacement, Keep the Blade Stable: step 3, image 1 of 1
      • We'll need to keep the blade stable as we're trying to loosen the nut so we'll need an object that keeps the blade in place. A brick is one option.
      Ask FixBot
    4. Toro 22-Inch Recycler Lawn Mower Blade Replacement, A Small Piece of Wood Can Also Stabilize the Blade: step 4, image 1 of 1
      • A small piece of wood is another option to keep the blade stable.
      Ask FixBot
    5. Toro 22-Inch Recycler Lawn Mower Blade Replacement, Select the Bit for the Socket Wrench: step 5, image 1 of 1
      • A socket wrench loosens the blade attachments. Attach a 5/8-inch bit to the socket wrench and we're ready to loosen the nut.
      Ask FixBot
    6. Toro 22-Inch Recycler Lawn Mower Blade Replacement, The Socket Wrench and Bit Removes the Nut: step 6, image 1 of 1
      • Turning the wrench to the left, we'll loosen the nut.
      Ask FixBot
    7. Toro 22-Inch Recycler Lawn Mower Blade Replacement, Remove the Blade: step 7, image 1 of 1
      • After loosening the nut, we're ready to remove the blade.
      Ask FixBot
    8. Toro 22-Inch Recycler Lawn Mower Blade Replacement, Ready to Mow the Lawn: step 8, image 1 of 1
      • Now that the blade has been removed and the necessary repairs have been made, you're ready for a nice afternoon under the sun and prepared to spruce up the lawn.
      Ask FixBot
Mike Marshall
280 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 66
All Time: 721
