Toptro TR23 Speaker Replacement
  1. Toptro TR23 Speaker Replacement, Case: step 1, image 1 of 3 Toptro TR23 Speaker Replacement, Case: step 1, image 2 of 3 Toptro TR23 Speaker Replacement, Case: step 1, image 3 of 3
    • Set the projector on its side so the the front is facing to your left.
    • Insert an opening tool into the seam between the black chassis and the silver case.
    • Pry around the perimeter until the case fully releases.
    • When removing the cover, be careful as there is an internal connector attached to the lid and the projectors motherboard. You’ll have to carefully detach that before fully removing the projector case.
    • Remove the case.
    Ask FixBot
  2. Toptro TR23 Speaker Replacement, speaker: step 2, image 1 of 3 Toptro TR23 Speaker Replacement, speaker: step 2, image 2 of 3 Toptro TR23 Speaker Replacement, speaker: step 2, image 3 of 3
    • Disconnect the motherboard speaker connector on the lower-left side of the motherboard.
    Ask FixBot
  3. Toptro TR23 Speaker Replacement: step 3, image 1 of 3 Toptro TR23 Speaker Replacement: step 3, image 2 of 3 Toptro TR23 Speaker Replacement: step 3, image 3 of 3
    • Remove the two 18.8 mm screws that secure the speaker to the Toptro TR23 with a Phillips #1 screwdriver.
    • Remove the speaker.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
evry1luvsj_
193 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 25
All Time: 285
