Toptro TR23 Motherboard Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
22
Past 30 Days:
76
All Time:
538
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Are there gremlins in your projector? Is your new projector's functionality in general disarray? Are you have trouble with hooking up your projector through USB or HDMI cable? Well, then you may need to replace the motherboard, and this guide will help you do that.
Before continuing on to the processes of taking this projector apart and ripping out the brains, I would do a few simple checks to makes sure it's not something else that is causing the issues. I would make sure that your projector is not in a spot where it could overheat. Say, in a corner or directly up against a wall with no ventilation. Then I would try factory resetting the projector, which could work out bugs in the system.
Before beginning make sure that the projector is unplugged from it's power source and is on a level sturdy work surface.
Tools
    1. Toptro TR23 Motherboard Replacement, Case: step 1, image 1 of 3 Toptro TR23 Motherboard Replacement, Case: step 1, image 2 of 3 Toptro TR23 Motherboard Replacement, Case: step 1, image 3 of 3
      • Set the projector on its side so the the front is facing to your left.
      • Insert an opening tool into the seam between the black chassis and the silver case.
      • Pry around the perimeter until the case fully releases.
      • When removing the cover, be careful as there is an internal connector attached to the lid and the projectors motherboard. You’ll have to carefully detach that before fully removing the projector case.
      • Remove the case.
      Ask FixBot
    1. Toptro TR23 Motherboard Replacement, Motherboard: step 2, image 1 of 3 Toptro TR23 Motherboard Replacement, Motherboard: step 2, image 2 of 3 Toptro TR23 Motherboard Replacement, Motherboard: step 2, image 3 of 3
      • Use your fingernails to gently disconnect the six sliding connectors from their motherboard sockets.
      • Gently lift the two antenna cable connector to disconnect them.
      Ask FixBot
    2. Toptro TR23 Motherboard Replacement: step 3, image 1 of 3 Toptro TR23 Motherboard Replacement: step 3, image 2 of 3 Toptro TR23 Motherboard Replacement: step 3, image 3 of 3
      • Flip up the black ZIF locking flap that secures the bronze ribbon cable.
      • Using your fingers carefully disconnect the ribbon cable.
      Ask FixBot
    3. Toptro TR23 Motherboard Replacement: step 4, image 1 of 3 Toptro TR23 Motherboard Replacement: step 4, image 2 of 3 Toptro TR23 Motherboard Replacement: step 4, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the four 7.3 mm screws securing the motherboard to the projector.
      Ask FixBot
    4. Toptro TR23 Motherboard Replacement: step 5, image 1 of 3 Toptro TR23 Motherboard Replacement: step 5, image 2 of 3 Toptro TR23 Motherboard Replacement: step 5, image 3 of 3
      • Gently lift the motherboard off to the left, with care not to strain the single remaining attached cable.
      • Disconnect the last connector from its motherboard scoket.
      • Remove the motherboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
evry1luvsj_
193 Reputation
2 Guides authored
1 Guide Comment
Where can I buy a motherboard for it?
Joseph Nemeth - Reply Share
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 76
All Time: 538
