Up to 20% off select tools
Toptro TR23 Case Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
92
All Time:
1,072
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the case on your Toptro TR23.
    1. Toptro TR23 Case Replacement, Case: step 1, image 1 of 3 Toptro TR23 Case Replacement, Case: step 1, image 2 of 3 Toptro TR23 Case Replacement, Case: step 1, image 3 of 3
      • Set the projector on its side so the the front is facing to your left.
      • Insert an opening tool into the seam between the black chassis and the silver case.
      • Pry around the perimeter until the case fully releases.
      • When removing the cover, be careful as there is an internal connector attached to the lid and the projectors motherboard. You’ll have to carefully detach that before fully removing the projector case.
      • Remove the case.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bassolino
27,057 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Guide Comment
I am afraid to say that this guide is misleading. The projector does not open the way it is described and I ended up breaking the screws. The way to open it is to unscrew the bolts holding the belt on top that is also screwed in to the body underneath. There a 2 concealed screws in the back where HDMI cable and aux jack is that are then removed to take the top flap off. Once done, you can then unscrew the bottom bottom stand and remove the casing.
Aman Paul - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 92
All Time: 1,072
