TopMate C11 Fan Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
23
Past 30 Days:
104
All Time:
1,113
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If one of the fans in your TopMate C11 laptop cooling pad stops working, it can impact your laptop's cooling performance, leading to overheating issues. This guide will show you how to replace the fan.
For added safety, consider using hand protection gloves during the handling of the mesh grill cover in steps 6 and 11 to prevent injuries from its sharp edges.
In steps 5 and 12, securely hold the mesh grill cover with the cooler while flipping to prevent the fans from falling out, as they are not secured inside.
Before beginning, make sure to disconnect your laptop cooler from power. Remember to follow general electrostatic discharge (ESD) safety procedures while replacing the fan.
Tools
    1. TopMate C11 Fan Replacement, Fan: step 1, image 1 of 1
      • Place the cooler on a flat surface.
      Ask FixBot
    2. TopMate C11 Fan Replacement: step 2, image 1 of 1
      • Flip the cooler upside down.
      Ask FixBot
    3. TopMate C11 Fan Replacement: step 3, image 1 of 1
      • Identify all 10 metal flaps.
      Ask FixBot
    4. TopMate C11 Fan Replacement: step 4, image 1 of 3 TopMate C11 Fan Replacement: step 4, image 2 of 3 TopMate C11 Fan Replacement: step 4, image 3 of 3
      • Straighten all 10 metal flaps with tweezers.
      Ask FixBot
    5. TopMate C11 Fan Replacement: step 5, image 1 of 2 TopMate C11 Fan Replacement: step 5, image 2 of 2
      • Flip the cooler while securely holding the mesh grille cover.
      Ask FixBot
    6. TopMate C11 Fan Replacement: step 6, image 1 of 3 TopMate C11 Fan Replacement: step 6, image 2 of 3 TopMate C11 Fan Replacement: step 6, image 3 of 3
      • Remove the mesh grille cover.
      • WARNING: Be careful with the mesh grille cover, it has sharp edges.
      Ask FixBot
    7. TopMate C11 Fan Replacement: step 7, image 1 of 1
      • Identify the broken fan.
      Ask FixBot
    8. TopMate C11 Fan Replacement: step 8, image 1 of 3 TopMate C11 Fan Replacement: step 8, image 2 of 3 TopMate C11 Fan Replacement: step 8, image 3 of 3
      • Trace the wire from the broken fan to the controller board.
      Ask FixBot
    9. TopMate C11 Fan Replacement: step 9, image 1 of 3 TopMate C11 Fan Replacement: step 9, image 2 of 3 TopMate C11 Fan Replacement: step 9, image 3 of 3
      • Gently press two points on the top of the white plug with tweezers to disconnect the wire.
      • Don't use excessive force. The wire is fragile.
      Ask FixBot
    10. TopMate C11 Fan Replacement: step 10, image 1 of 3 TopMate C11 Fan Replacement: step 10, image 2 of 3 TopMate C11 Fan Replacement: step 10, image 3 of 3
      • Replace the fan and connect the wire.
      • Make sure to put the fan in the correct orientation.
      • Make sure also the white connector is fully connected.
      Ask FixBot
Dominic Botlero
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 104
All Time: 1,113
