Up to 20% off select tools
Top Shell
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
114
All Time:
2,635
Comments: 5
5 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Top Shell
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Top Shell, Engage Wired Optical Mouse Top and Outer Shell Removal: step 1, image 1 of 1
      • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
      Ask FixBot
    2. Top Shell: step 2, image 1 of 1
      • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
      • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
      Ask FixBot
    3. Top Shell: step 3, image 1 of 3 Top Shell: step 3, image 2 of 3 Top Shell: step 3, image 3 of 3
      • Grab the top shell of the mouse and lift up to remove.
      Ask FixBot
    4. Top Shell: step 4, image 1 of 1
      • The capacitors on this board can release stored electrical energy if touched.
      • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
      Ask FixBot
    5. Top Shell: step 5, image 1 of 2 Top Shell: step 5, image 2 of 2
      • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
      Ask FixBot
    1. Top Shell, Top Shell: step 6, image 1 of 1
      • Remove the 5 mm round head screw holding the middle piece to the top piece.
      • The outermost shell will now separate from the middle structure.
      Ask FixBot
3 other people completed this guide.
Author
with
David
1,316 Reputation
4 Guides authored
Cal Poly, Team 18-36, Regan Winter 2013 Member of Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 114
All Time: 2,635
