Up to 20% off select tools
Top Cover Removal
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
76
All Time:
822
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Difficult
Community-Contributed Guide
Top Cover Removal
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the top cover of the Pentax MZ-S. Removing the top panel is often the starting point of more in depth repairs.
    1. Top Cover Removal, Remove film door: step 1, image 1 of 1
      • Push down the latch to release the film door.
      Ask FixBot
    2. Top Cover Removal, Remove top cover screws: step 2, image 1 of 3 Top Cover Removal, Remove top cover screws: step 2, image 2 of 3 Top Cover Removal, Remove top cover screws: step 2, image 3 of 3
      • Remove two 7.5 mm #00 screws.
      • Remove one 9.0 mm #00 screw.
      • Remove one 13.5 mm #00 screw from inside the battery compartment.
      Ask FixBot
    3. Top Cover Removal, Remove top cover screws: step 3, image 1 of 3 Top Cover Removal, Remove top cover screws: step 3, image 2 of 3 Top Cover Removal, Remove top cover screws: step 3, image 3 of 3
      • Push the button to pop up the flash.
      • Remove one 3.5 mm #00 screw.
      • Remove one 5.5 mm #00 screw.
      Ask FixBot
    4. Top Cover Removal, Lift top cover: step 4, image 1 of 1
      • Carefully lift the top cover away from the body to access wired connections.
      • The top cover is still connected in several locations.
      Ask FixBot
    5. Top Cover Removal, Access flash connections: step 5, image 1 of 2 Top Cover Removal, Access flash connections: step 5, image 2 of 2
      • Peel back the corner of the rubber grip.
      • Remove the small plastic cover.
      • Be careful not to short the wires before the flash capacitors have been properly discharged.
      Ask FixBot
    6. Top Cover Removal, Discharge flash capacitors: step 6, image 1 of 1
      • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
      • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
      Ask FixBot
    7. Top Cover Removal, Disconnect right flex cable: step 7, image 1 of 1
      • Carefully lift the sides of the white latch.
      • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
      Ask FixBot
    8. Top Cover Removal, Disconnect left flex cable: step 8, image 1 of 1
      • Desolder the red wire.
      Ask FixBot
    9. Top Cover Removal, Desolder flash connections: step 9, image 1 of 2 Top Cover Removal, Desolder flash connections: step 9, image 2 of 2
      • Desolder blue, black, brown and green wires.
      • Remove the loose shim washer if present.
      Ask FixBot
    10. Top Cover Removal, Desolder the flash flex cable: step 10, image 1 of 2 Top Cover Removal, Desolder the flash flex cable: step 10, image 2 of 2
      • Remove the piece of cellophane tape covering the flex connections.
      • Desolder flex connetions.
      Ask FixBot
Author
with
Sam Gustafson
14,888 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 76
All Time: 822
