Up to 20% off select tools
Tool Cart Wheel Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
33
Past 30 Days:
130
All Time:
2,622
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you would like to replace the wheel on a utility cart, or even rearrange the wheels, use this step by step guide to do so. This guide can be useful if a wheel on your utility cart breaks or if you simply want to replace your wheels.
    1. Tool Cart Wheel Replacement, Wheel: step 1, image 1 of 3 Tool Cart Wheel Replacement, Wheel: step 1, image 2 of 3 Tool Cart Wheel Replacement, Wheel: step 1, image 3 of 3
      • Flip the cart over so that the wheels are facing up.
      Ask FixBot
    2. Tool Cart Wheel Replacement: step 2, image 1 of 2 Tool Cart Wheel Replacement: step 2, image 2 of 2
      • Use the Phillips #2 screwdriver to remove all the screws from the metal plate.
      Ask FixBot
    3. Tool Cart Wheel Replacement: step 3, image 1 of 2 Tool Cart Wheel Replacement: step 3, image 2 of 2
      • Remove the old wheel.
      • Place the new wheel with the metal plate directly on top of the cart so that the holes on the metal plate are aligned with the holes on the cart.
      Ask FixBot
    4. Tool Cart Wheel Replacement: step 4, image 1 of 1
      • With the Phillips #2 screwdriver, secure the screws back in diagonally.
      Ask FixBot
    5. Tool Cart Wheel Replacement: step 5, image 1 of 1
      • Insert and secure the other two screws.
      Ask FixBot
Finish Line
Author
with
Erika Soto
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 130
All Time: 2,622
