This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Toniebox Disassembly
  1. Toniebox Disassembly, Toniebox Opening Procedure: step 1, image 1 of 2 Toniebox Disassembly, Toniebox Opening Procedure: step 1, image 2 of 2
    • Put the Toniebox on a flat surface (e.g. a desk or a workbench).
    • Apply some pressure and turn the Toniebox counterclockwise to unlock the two clips beneath the bottom plate.
    • You will hear a "klick" when the two clips unlock.
    Ask FixBot
  2. Toniebox Disassembly: step 2, image 1 of 1
    • Remove the bottom plate.
    Ask FixBot
  3. Toniebox Disassembly: step 3, image 1 of 1
    • Remove the Phillips #1 screw on the bottom of the Toniebox.
    Ask FixBot
  4. Toniebox Disassembly: step 4, image 1 of 1
    • Lift the inner part out of the foam housing.
    Ask FixBot
  5. Toniebox Disassembly, Removing the Battery Compartment: step 5, image 1 of 2 Toniebox Disassembly, Removing the Battery Compartment: step 5, image 2 of 2
    • Pull the inner-plastic part out of the body
    • Loosen the two screws on the battery compartment and then carefully remove the battery compartment.
    Ask FixBot
Follow the steps in reverse, in order to put your device back together.
Special thanks to these translators:
de en
80%
These translators are helping us fix the world! Want to contribute?
Start translating ›
twayne Markinson
1,470 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 68
All Time: 3,536
