Toniebox Broken Ear Repair
Views: 93K
View statistics:
Past 24 Hours:
24
Past 7 Days:
210
Past 30 Days:
890
All Time:
92,511
Comments: 28
12 comments on steps, 16 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Archived Guide This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
Use this guide if one of the ears has stopped working.
If your button is not broken and only the cable has been torn off, skip the steps to replace the button.
If your button is broken but your cable is not torn off, skip the steps to repair the cable.
    1. Toniebox Broken Ear Repair, Toniebox Opening Procedure: step 1, image 1 of 2 Toniebox Broken Ear Repair, Toniebox Opening Procedure: step 1, image 2 of 2
      • Put the Toniebox on a flat surface (e.g. a desk or a workbench).
      • Apply some pressure and turn the Toniebox counterclockwise to unlock the two clips beneath the bottom plate.
      • You will hear a "klick" when the two clips unlock.
      Ask FixBot
    2. Toniebox Broken Ear Repair: step 2, image 1 of 1
      • Remove the bottom plate.
      Ask FixBot
    3. Toniebox Broken Ear Repair: step 3, image 1 of 1
      • Remove the Phillips #1 screw on the bottom of the Toniebox.
      Ask FixBot
    4. Toniebox Broken Ear Repair: step 4, image 1 of 1
      • Lift the inner part out of the foam housing.
      Ask FixBot
    1. Toniebox Broken Ear Repair, Removing the Battery Compartment: step 5, image 1 of 2 Toniebox Broken Ear Repair, Removing the Battery Compartment: step 5, image 2 of 2
      • Pull the inner-plastic part out of the body
      • Loosen the two screws on the battery compartment and then carefully remove the battery compartment.
      Ask FixBot
    1. Toniebox Broken Ear Repair, Remove the defective button: step 6, image 1 of 3 Toniebox Broken Ear Repair, Remove the defective button: step 6, image 2 of 3 Toniebox Broken Ear Repair, Remove the defective button: step 6, image 3 of 3
      • Remove the ears from the Toniebox according to the basic instructions for the Toniebox Teardown. Be especially careful not to damage the connector on the PCB.
      • Gently pull the inner ears down and out. Do not pull on the cable!
      • Use a pair of tweezers to carefully pull the defective button and PCB out of the silicone ear. If the cable is not torn off, be careful not to damage it.
      Ask FixBot
    2. Toniebox Broken Ear Repair, Desoldering the defective button: step 7, image 1 of 3 Toniebox Broken Ear Repair, Desoldering the defective button: step 7, image 2 of 3 Toniebox Broken Ear Repair, Desoldering the defective button: step 7, image 3 of 3
      • Solder the defective button from the PCB. The best way to do this is to use a hot air gun/ soldering iron around 360 ° C
      • Remove the excess solder with desoldering braid.
      Ask FixBot
    3. Toniebox Broken Ear Repair, Solder the new button: step 8, image 1 of 1
      • Use lead free solder to reattach the replacement button
      Ask FixBot
    4. Toniebox Broken Ear Repair, Soldering the torn cable: step 9, image 1 of 3 Toniebox Broken Ear Repair, Soldering the torn cable: step 9, image 2 of 3 Toniebox Broken Ear Repair, Soldering the torn cable: step 9, image 3 of 3
      • Remove the remains of the torn strand from the solder pads with the soldering iron
      • Isolate approx. 3mm from each wire of the line
      • Tin each pad and solder them on the back of the PCB. One wire on each pad. Be careful that the wire has no contact with outer copper surfaces.
      Ask FixBot
    5. Toniebox Broken Ear Repair, Installation of repaired button: step 10, image 1 of 3 Toniebox Broken Ear Repair, Installation of repaired button: step 10, image 2 of 3 Toniebox Broken Ear Repair, Installation of repaired button: step 10, image 3 of 3
      • Carefully put the circuit board back into the ear.
      • Lay the strand in the designated channels.
      • Push the inner ears back into the ear sleeve using the buttons.
      Ask FixBot
15 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
twayne Markinson
1,500 Reputation
6 Guides authored
16 Guide Comments
Bei unserer Box ist der Schalter samt Platine weg. Kann man das Kabel auch direkt am Schalter anlöten oder hat die Platine eine Funktion?
Kevin Flaig - Reply Share
Hi,
die Platine hat keine elektrische Funktion. Sie dient nur mechanisch dazu den Taster zu stützen. Wenn du es schaffst den direkt anzulöten geht das auch, ich weiss allerdings nicht wie gut das Veralten beim drücken ist oder ob das wider kaputt geht. Hier habe Ich neue Platinen gesehen die man allerdings selbst noch etwas bearbeiten muss:
https://www.ebay-kleinanzeigen.de/s-anze...
twayne Markinson - Reply Share
Hier gibt es auch neue Platinen:
http://www.ebay-kleinanzeigen.de/s-anzei...
Ansonsten hat die keine Funktion. Ihr könnt die Kabel auch an die Taster direkt löten.
Moin
Bei uns sind die ohren durchgeknabert. Ich will nur die orhen erneuern wo kann man die kaufen?
Matthias Lehmann - Reply Share
Ich kann gerne einige 3D-Drucken und sie verschicken.
Benoit74 - Reply Share
Past 24 Hours: 24
Past 7 Days: 210
Past 30 Days: 890
All Time: 92,511
