TomTom XL Battery Replacement
Views: 53K
View statistics:
Past 24 Hours:
3
Past 7 Days:
41
Past 30 Days:
141
All Time:
52,847
Comments: 15
3 comments on steps, 12 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Guide to replace the battery in the Tom Tom XL.
Parts
Tools
    1. TomTom XL Battery Replacement, Screen and Motherboard: step 1, image 1 of 1
      • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
      • Starting at the corners, carefully pry up the screen bezel.
      Ask FixBot
    2. TomTom XL Battery Replacement: step 2, image 1 of 1
      • Remove the four Phillips #00 screws around the edge of the screen.
      Ask FixBot
    3. TomTom XL Battery Replacement: step 3, image 1 of 3 TomTom XL Battery Replacement: step 3, image 2 of 3 TomTom XL Battery Replacement: step 3, image 3 of 3
      • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
      • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
      • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
      • Remove the frame from the housing.
      Ask FixBot
    4. TomTom XL Battery Replacement: step 4, image 1 of 2 TomTom XL Battery Replacement: step 4, image 2 of 2
      • Lifting from the upper edge of the screen, tilt the screen away from the device.
      • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
      Ask FixBot
    5. TomTom XL Battery Replacement: step 5, image 1 of 2 TomTom XL Battery Replacement: step 5, image 2 of 2
      • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
      • Two Phillips #00 screws are located at the bottom of the first picture.
      • The third screw is hidden under the orange ribbon cable, near the screen.
      • You may have to carefully lift the screen in order to reach this screw.
      Ask FixBot
    6. TomTom XL Battery Replacement: step 6, image 1 of 2 TomTom XL Battery Replacement: step 6, image 2 of 2
      • Flip the screen and motherboard over.
      • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
      • Disconnect the speaker cable connector from the motherboard.
      • Remove the motherboard and screen from the housing.
      Ask FixBot
    1. TomTom XL Battery Replacement, Battery: step 7, image 1 of 1
      • Slip a small plastic opening tool under the battery and slowly pry the battery up.
      • The battery is held on with strong adhesive, so it may require some force. Work slowly and carefully to avoid damaging the housing
      • Remove the battery from the housing.
      Ask FixBot
13 other people completed this guide.
Sean Higginson
209 Reputation
2 Guides authored
Cal Poly, Team 33-84, Johann Spring 2010 Member of Cal Poly, Team 33-84, Johann Spring 2010
CPSU-JOHANN-S10S33G84
4 Members
48 Guides authored
12 Guide Comments
Note: There are several variants of this. Some of them have 2 screws on the bottom under the stickers. You'll need to remove those first.
nathan - Reply Share
Awesome and very detailed guide. Thanks for this.
Phil Harris - Reply Share
Great demo, for replacement tomtom batteries take a look at : TomTom batteries
based in the UK they are reliable and give a truly longer charge
Kermit45 - Reply Share
This was a great help. Followed the instructions and it was that easy. Thanks
mark - Reply Share
nathanrenniewaldock is right... I cracked my screen before finding the hidden screws on the bottom. what a silly company to use the same name for different models!
Laz - Reply Share
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 141
All Time: 52,847
